Question about GE EGR3000 Gas Kitchen Range
Can't get the oven to come on
Bought the stove second hand...don't know how to work the oven control or the temperature control...there is not a knob with numbers on it for temperature...does it have some control on the panel...this is a self cleaning oven... do you have to light the ignitor or some type of pilot? boy, i feel silly...need help
    President:
  • 1,723 Answers
Go here to look at manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802063.pdf
Posted on Jul 18, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
Model pod712mw microwave doesnot work oven simply stopped working
If there is a fuse, it will be located inside the oven behind the control panel. Gain access to the panel and inspect for signs of fuse. If not, and the oven has no power whatsoever, for any function, and the power supply is good, then there will be a fault in the appliance somewhere. Most likely the brain.
Generally, the fuse is located in one of the panels on the front, behind the control panel/knobs. Keep in mind that a lot of stoves don't have the fuse no, its silly really. I reemmber in other customer problems that the problem was a temperature control regulator that had burned out,
Will need to check and re-check all internal components in your device.
Hope helps.
Jul 14, 2011 | Microwave Ovens
Tappan oven "turns on" by "itself" ??? Control
I cannot solve this problem yet. We have the same problem. However in ours if we turn the temperature know to off (the other knob is set to off - time bake, bake, broil, clean, etc - set to off) then it will not run. Somehow that temperature knob with the electrical control is making it turn on. Ours started to do this on the same day!
Apr 16, 2011 | Kitchen Ranges
My oven is at least 15 degrees cooler than it should be. Since I have a digital stove, does that mean it cannot be repaired?
Try this
Turn oven temperature knob to OFF.
2. Press and hold both arrow pads for approximately 5 seconds.
3. A double digit will display ranging from -35 °F to 35 °F.
4. Immediately, press either:
• to increase oven temperature by 5 °F
• to decrease oven temperature by 5 °F
• When temperature is adjusted to a cooler setting, a minus sign (-) will
display with the offset temperature.
5. When desired temperature change is displayed, release control and
change will be automatically saved after a few seconds. Control will
return to time of day display.
• Offset temperature change will be retained through a power failure.
The complete manual can be downloaded at www.appliancehelponline.com just enter your model # and the manual will be on the left hand side.
Nov 05, 2010 | Amana ACF4215 Electric Kitchen Range
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Jul 13, 2009 | Kitchen Ranges
1. Product is a used G.E. Stove. 2. It has a self-cleaning oven. 3. It has an oven control knob with the following features that go clockwise according to these. a. preheat b. warm c. temperatures d....
Check the clock timer you may have programed a clean start time into it. Also can you give the model number it is on the door edge or near by the door when open. Let me know if that worked
Dec 21, 2008 | Kitchen Ranges
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
GE EGR3000 Gas Kitchen Range Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
