Question about Garden
Simplicity sunstar 20hp rear pto won't engage deck when you flip the switch, it used to work for a while and I could play with it and it would work but now nothing, any suggestions.
Your electric clutch may need adjustment. Take the hood off. Look behind the double pulley that's on the crank shaft. Behind the pulley is an electric clutch. You will need a .010-.015 feeler gage and check between the clutch plates. You will tighten the three screws that mount the clutch to the motor. Try and get as close to .010" as you can. After adjustment start the motor and try and engage the pto. I bet it will work.
Good luck
Posted on Aug 24, 2009
My simplicity riding lawn mower was submerged for about a half hour and will not start. what should I do?
change the sump oil , remove the plug and dry off, turn motor over with out the plug to empty water from the cylinder
remove fuel tank and empty water out , remove carby and empty water out
check all switches for water immersion
Jul 24, 2016 | Simplicity Broadmoor 20hp Briggs &...
What belt engages the blades
pto belt engages deck then you have a deck b elt
Sep 02, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
It won't crank
I would think one of your safety switches aren't making. Could be the seat switch, neutral lever isn't made, blade engagement lever is in the engaged position and this will not allow the motor to be turned over. Try that!
Mar 29, 2013 | Simplicity Legacy 20hp 48 Inch Deck /...
Won't start.
There are a number of safety switches on mowers today for example one for the seat, pto (deck being engaged) There may also be a blown fuse as you said the hour meter is not working
Oct 23, 2012 | John Deere Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
Apr 03, 2012 | Garden
Blade will not engage but all saftey features works
With the pto switch pulled out check with a multi meter that you have a 12 volt supply the the clutch, pull the connector apart at the clutch end to do this, if there is no supply it is a switch or wireing issue, if there is a supply, you shouls have an audible click when the pto switch is pulled out, this is the elecro magnetic clutch engaging, if the click is present, check the belt from the clutch to the deck.
Mar 06, 2012 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
1990 20hp Sunstar Rear PTO cuts out during rototilling operations, if I turn off switch and turn back on it will work for a little bit but then cuts out again. I recently replaced my engine with a 24hp...
Did you install the original electric clutch from the old engine?
If so, you may not have the adjustment right. On most electric clutches, there is a specific distance between the drive plate and the driven plate. Check your shop manual (if you have one) for this, as it does vary between manufacturers, and depending on the size of clutch.
Apr 17, 2009 | Garden
Garden Logo
929 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
