Question about GE Microwave Ovens
JE 1425L 003, RUNS WITH DOOR OPEN - GE Microwave Ovens
  • GE Master
  • 9,098 Answers
It may just be a bad door switch or door switch mount, which are easy to check.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can access the door switches & mounts.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/doorsw.txt
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you only need a switch, you can order a universal type here for $5 postpaid.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Jul 20, 2009
My GE Microwave Convection Oven model JE 1390WV runs whenever the door is open. It microwaves on the normal settings, but when the door is opened it turns on and runs.
DO NOT USE IT!!!! THERE IS A SWITCH IN THE DOOR LATCH THAT NEEDS TO BE REPLACED.
AGAIN DO NOT USE IT!!!! IF ITS RUNNING WITH THE DOOR OPEN YOU COULD DO SERIOUS DAMAGE TO YOUR HAND OR ARM IF IT IS NEAR THE OPEN DOOR
Sep 19, 2017 | GE Microwave Ovens
Can I get a replacement door fory GE microwave, Model KVM1542wv 003
http://www.appliance-parts-experts.com/Microwave-Oven-Parts_c_527.html
Mar 12, 2015 | GE Microwave Ovens
JE 1660 microwave is completely dead.
The microwave fuse has blown, often caused by a defective door switch.
May 09, 2011 | GE JE1660 Microwave Oven
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
How do you replace the handle on a ge Space Master Oven JVM 1490 BD 003
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Apr 28, 2009 | Microwave Ovens
Microwave working when door opens
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 08, 2008 | GE JE1660 Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
