Question about Garden
Weedeater trimmer not engaging
I have a 705r weedeater & while taking it apart to f eplace the fuel lines, I apparently did something to keep the head from turning eventhough the engine now runs. What do I need to do to get the head to engage?
  • 155 Answers
Maybe on reassembly the drive shaft did not align properly.
Posted on Jul 25, 2009
Homelite weedeater not spinning
there is a cable that runs thru to the shaft take it apart at the shaft bottom and see if it is broken or unattached.
May 15, 2014 | Homelite Garden
Weedeater ght 180 wont start
You'll probably need to remove the carb and clean it out. Sounds like the fuel passages may be clogged.
Oct 05, 2012 | Weedeater Gas Powered Hedgetrimmer...
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Blades not moving on ss24 weedeater
I just disassembled a SS24 hedge trimmer that had the same problem of the blades not moving. The problem is that there are 2 or 3 teeth on the helical gear that are missing. Consequently, the small gear on the motor shaft cannot continuously engage the gear that moves the blades back and forth.
May 27, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Weedeater fuel line oopsy
I fed the fuel line up through the bottom, attached the filter and pulled it backk towards the hole in the bottom of the tank. I then used a brake adjustment tool to first push the filter back in place (with the line attached) then hold by pressing down on the top of the filter while I hooked up the little plastic clamp.
All that seems to work fine but the weed eater won't idle AT ALL.
May 02, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
