Question about Garmin nuvi 200W GPS Receiver
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
  • 2,335 Answers
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Posted on Apr 17, 2010
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
My home base is Ohio. I am now in Texas and my Garmin Nuvi 265W seems unable to acquire a satellite signal for my current location. How can I get a satellite signal that I can use in Texas?
One problem, which I've experienced, are tinted windows (tinted with metal oxide). They block or distort the microwave signal to/from the satellite. Garmin has an optional external antenna which can be used, or you can try relocating the GPS in your car. Try it with all windows down and the unit near an open window. If that works you've confirmed the tinted glass problem.
Jan 18, 2011 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi 1300 is having trouble locating satelites
You should place it as far forward on the dash as possible, underneath the front part of the windshield. That gets it out from underneath the metal roof of the car so that it can receive the satellite signal.
Dec 05, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin 205 seems to have lost its fix. Its position is out by about 100m, tracking established roads but to one side or other then loses roads altogether then gets totally lost. Is a map update...
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device. There have been numerous fixes to the firmware to allow the Garmin 205 or acquire satellite signal faster, and to be more accurate with your location.
I hope that helps.
Feb 08, 2010 | Garmin nuvi 205 GPS Receiver
Trouble locating satellite signal
try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 13, 2009 | Garmin nuvi 1300 Car GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Just purchased a garmin nuvi 205W in Florida. It
This device should find a signal nearly anywhere it is used. The further away from the earth's equator it is used will increase signal lock or "fix" time though. You should be able to get a fix by bringing the unit into an open space (few / low trees, buildings, etc.) and leave on for up to 20 minutes. The GPS should provide an accurate location in this amount of time and should be able to fix in a moment or so from that point on.
If you have troubles still, contact Garmin Support below:
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
Trouble locating satellites
Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
Apr 24, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
884 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
