Question about HP LaserJet 1022n Printer
Printing accurately Sir I am trying to print label on desmat labels (label size "99mm x 34mm") through MS WORD, but not getting accurate prints, contents are not coming inside the cut marks of label. My printer is HP1022n. Please help me. Thanks Vijay Kumar
  • Anonymous Mar 25, 2014
    labels going inside the machine instead of coming out when printing
    labels are going backward when printing instead of coming out
  • 417 Answers
Hi there within the envelopes and labels print function within MS Word you will be able to set the correct label and sizes. If this doesn't work then adjust the margins.
This problem is nothing to do with your printer as you are sending a command to it and the printer is doing what you told it to do. Check the settings first.
Thanks J
Posted on Jan 13, 2008
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
Cannot print graphics accurately. Barcode and text
Problem with your software.
Tec do have instructions for printing diagonals.
Your software must be sending graphics with grey pixels.
Nov 03, 2010 | Toshiba TEC B-472 Thermal Label Printer
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
HP Photosmart Premium c309a series will not print envelopes. I keep getting an error message that says paper mismatch. It doesn't matter what size envelope I put in, it always gives me an error message....
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Sep 21, 2009 | HP Photosmart Premium C309A All-In-One...
Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
Sep 17, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the printer will calibrate the label..
if still the problem exist .check the notch in the ribbon adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
I have an HP 5550 Series Deskjet printer. Only recently, I have encountered difficulty printing labels. I have double-checked the Printing Properties, including label size, label paper size, Avery paper #,...
This printer have the capabilites of sense the size of label, each colomn width.
So, you must set the right size of colomn width, in your application (ms. word) to match label width.
May this help.
Oct 10, 2008 | Office Equipment & Supplies
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Label Printing
The printer is not the issue here...That is a great printer BTW.
The issue is which program are you using when trying to print out these labels? Do you have Microsoft Word, Works, or some simular word processor program installed on your computer?
There are free document templates that have all the settings for printing 2 x 4 labels and others. Here is a link for a 4 x 2 tem-late that would work in any version of Word, SureThing CD Labeler and any program that handle PDFs.
You can take label printing to the next level by using a program that will read in your address book and print each on one label automatically. You don't spend time trying to type them all in.
If yo have MS word, look under HELP for "mail merge", that wil get you on the right track.
Let me know =)
Mar 31, 2008 | OKI C9300 Led Printer
HP LaserJet 1022n Printer Logo
194 people viewed this question
Ben Johnson
