Question about Weber Q Grill
Grill will not light
I have gas but cannot get gas to pass through regulator. Could it be bad?
  • 57 Answers
It a bad regulator go to home depot and buy one
Posted on Aug 27, 2009
We have permasteel gas BBQ grill. grill can be lighted up, but gradually died off. It seems that no enough gas pressure and flows. The regulator gets iceing and cold.
too much gas passing from reg causing freezing of gas reg or line or check for gas leak on reg , reg could be stuck open again too much gas pasing .
Jul 04, 2012 | Thermos Stainless Steel Gas Grill
I have a SureFire Grill (SF30HOLP) that I recently converted to NG. For some reason the gas will flow through the regular and light, but at times I am not getting gas through the regulator. I have a...
I would try replacing the regulator, not very expensive and easy to do, first. If that doesn't fix the problem, call the gas company and see if there is a flow problem to the line itself. I have worked on grills that were operating properly, but there just wasn't enough gas flow in the line for the grill.
Jul 04, 2011 | Surefire Grilling
Lights but does not heat up beyond 250degrees
If this is a propane grill, try replacing the regulator and hose going to the tank. When a regulator is failing, it allows gas to pass, but not enough to allow the grill to heat up properly. If this is an older grill. You can also check each burner for blocked gas ports. Just a few blocked ports in a burner can prevent the burner from lighting completely, or from moving from one side of the burner to the other.
Jul 03, 2011 | Jenn-Air Grilling
Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
Apr 06, 2010 | Weber Genesis Silver B Grill
Having problems lighting baby q grill. have followed all the procedures. I am on my second regulator. i believe I believe that I have inferior regulators.
If you are getting a strong gas flow when you turn on the valves, then it may not be the regulator. If you are using the ingintor to try and light the grill, it could be a bad ingnitor, a bad or loose wire going to the electrode, or the gap between the electrode and the metal maybe to large to create a spark. If you can light it with a match or a manual butane lighter, then it is probably not the regulator.
Jan 10, 2010 | Weber Q Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Grill will not light, i have gas in tank but can not hear gas
If your bottle is full , could be the regulator or spiders have webbed up the lines , check theses potential problems. Hopefully this helps you out.
Jul 26, 2009 | Weber Genesis Gold B Grill
Grill won't heat pass 300 degrees, burner and lines clear of obstruction, could the problem be in the regulator?
yes, these regulators are known to get stuck. Try kinking the hose until you her a click in the regulator, this will open the valve. It may close again shortly after you release the pressure but worth a try.
Apr 04, 2009 | Thermos Stainless Steel Gas Grill
Weber Q Grill Logo
364 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
