Question about Garden
Missing or a poping sound when NOT under load
  • 130 Answers
Sound like the valve need to be ajusted need more information on it want kind mower is it
Posted on Jul 18, 2009
2000 Ford mustang. engine skipping and check engine light flashing. I have checked plugs and wires and they seem fine.
It sounds like you have a misfire. Does it miss more under a load or does it miss primarily,at idle. If under load, it is likely ignition related. Spray water on the wires and coils with the engine running. If they are carbon tracking it will be very obvious as the engine will miss worse.
Jun 25, 2014 | Cars & Trucks
Poping noise in front suspension on the 2011 CTS-V
front strut top bearing is worn, 2011 should still be under warranty
Dec 25, 2012 | 2011 Cadillac CTS-V
Poping sound from rear end
it can be your parking brake shoe in the rear that is inside the rear rotor. there is a brake pad and a parking brake shoe in the rear
Dec 22, 2012 | 2000 Mercury Mountaineer
Misses and sputters at certain throttle position
This sounds like the same problem I had with my 87 Jeep 2 door Cherokee Sport.
Thought I had to replace the Fuel pump yet when I went under and pulled it out of the side of the tank I found that one of it's vacuum or return line had fallen/poped off. After I pushed the rubber tube line back on it's metal tube and pushed and remounted the pump back in the tank. Started up and it never ran better at any speed. Yea!!!!!
Feb 25, 2012 | 1987 Jeep Cherokee
My 2005 cts misses when going up hills on the highway. i push the gas peddle down further and it is fine?
You notice the miss when going up a hill because you are putting the motor under load, sounds like time for tune-up, pretty sure the miss is there all time, but you just notice it more when under load
Apr 09, 2011 | 2005 Cadillac CTS
Back fires thru carb when excellerating but lopes when u take off manual trans
do you hear a pop pop poping under heavy acceleration or just one big back fireing when first accelerating? it could be an intake valve pop pop poping,and electrical,on the big bafireing under lite to med load. A cracked,or worn cap and rotor,weak coil wire,dirty carbruator,faulty accelerator pump in carb bad vacumn advance !slow ignition timing. BAD points and condenser if equiped on older model with carb.
Sep 01, 2010 | Jeep Cherokee Cars & Trucks
It makes a poping sound under a load like one plug does not fire then it does
Sounds like you have either a weak coil, a weak spark plug wire, or a bad plug. Replace your spark plugs first, they're the least expensive and easiest to replace.
To test the coil you need a "spark tester". It's a thing that looks like a writing pen but is adjustable. It will tell you the "strength" of your spark.
Good Luck
Steve
Aug 22, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
Loud poping sound under truck when driving as up and down shiftin
Could be the ujoints ,just a couple of bolts that hold in UJoint...Have you checkes your trans and motor mounts?
Jan 23, 2009 | 1996 Ford Ranger SuperCab
Nothing but Red Screen
check to see if you noticed some liquid on some of the wires on the red crt could the crt coolent be leaking onto the board under the crt and the blue crt is missing alot of coolent!!!
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
