Question about Dryers
My neptune dryer makes all my clothes reak. I have cleaned the air vent out and I didnt see any dead cats or anything like that. Clothes smell like they have been in the dump. They come out of the washer smelling spring fresh
    President:
  • 1,714 Answers
You may have lint mildewing in the vent. Take the vent tube off the back and reach in the back and see if there's lint stuck in there. Clean the vent tube also. Use a dryer sheet to help with the smell
Posted on Jul 18, 2009
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Maytag dryer is taking forever to dry clothes, can even smell bad while running? how do i clean it besides the lint catcher?
Make sure the vent is not clogged. Its in the bottom of back side. Typically vented outside. Also, verify your heater elements are working by running dryer with door open to check for heat
Jul 27, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer smells like kerosene!
The smell you are referring to is being caused by aldehydes. The gas burner has incomplete combustion is smothering. Make sure the moisture vent and pipe are not restricted. Try running the dryer with the moisture vent disconnected and see if the problem continues and make sure air flow thru hose is good. Also check outside where the dryer vent exits and make sure there is plenty of air flow. This particular dryer has an inducer fan that pushes the air to the burner and a blocked/plug vent will cause this. You may have to dis-assemble the dryer and inspect the burner compartment for lint build up and restrictions to burner compartment.
Sep 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Feb 21, 2009 | Maytag Neptune MDE7500AY Electric Dryer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be cleaned.you must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
Smell
Have you recently painted or finished any woodwork or floors? A gas dryer will smell like gas when the vapors from paint or finishes reacts with flame. It can smell like gasoline.
Nov 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
158 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
