Question about PNY 2GB microSD Memory Card
Write protection new 2GB micro sd with adapter. Everytime I try to copy music, I get the same error of write protected. I have tried several of time to movel the lock switch and tried to remove the write protection (maybe doing incorrect) Still can not figure this out.
    Problem Solver:
  • 6 Answers
I had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!
Posted on Jul 28, 2009
How do I unlock micro sd flash memory card?
I guess u using adapter & there is small little pin on the side whitch u can move to position lock or unlock
Apr 05, 2013 | SanDisk 2gb Micro Sd Trans Flash Memory...
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I am trying to sync music to my memory card but windows media keeps telling me that my memory card was write protected. How do I fix this?
If ou're using a Micro SD Adapter then there's a little tab on the side that when slid down write protects the Card thats inserted.
Jul 09, 2011 | SanDisk 2GB microSD Memory Card
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
Hello, i have a write protected micro SD card-2gb on Nokia 2700.
have you try format the memory first in the pc not in the phone sometimes virus in the phone block the memorys
May 16, 2010 | Cell Phones
Iam trying to download music on my sandisk micro card and it keep saying card is protected unprotect or use other disk
If you look at your micro sd card check for a switch that you can move. Move it in the opposite direction of that it is currently in. If this doesn't work try to change the switch on your sd adapter as well. If this still doesn't work switch the micro sd switch back to original state and try again. One of the cards has the lock activated. You just have to figure out witch one.
Please rate!
Cheers
Sep 28, 2009 | SanDisk 2GB microSD Memory Card
Samsung micro sd memory card
THE CARD IS WRITE PROTECTED
OR THE FILES COPIED ARE WRITE PROTECTED.
SO REMOVE THE WRITE PROTECTION ITS LIKE A SMALL SWITCH WHICH SLIDES ON THE CARD .. ONLY CERTAIN CARDS HAVE IT .
NOW IF THIS DOESNT WORK
PUT THE CARD IN A PHONE AND SEE PROPERTIES OF THE DATA THERE , REMOVE WRITE PROTECTION .
Jun 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PNY 2GB microSD Memory Card Logo
206 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
