Question about Pool & Spa
While vacuuming my pool the pumpgot clogged and shut off. after cleaning out it still keeps shuting off. did reset the circuit to no avail.
  • 3,230 Answers
You need to check it again......
may be it clogged due to broken pump fan inside.
you need to open that motor to check that blockage....
Thanks
Posted on Jul 18, 2009
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
Vacuum runs for 5 minutes ,then shuts down. Will restart after 15 minutes, then does same thing.
sounds like a built in feature. It is overheating, bad wire or circuit possible
Jan 01, 2015 | Vacuums
Reset button on hoover wind tunnel
Hi there! There is no reset button on the cleaner. The vacuum has a thermal protector sensor that will shut the vacuum off when the motor reaches a certain temperature. This is usually caused by a clog or filter that needs to be cleaned or replaced. Be sure to check the hoses for clogs and clean and replace any filters if needed. The vacuum will turn back on when it cools off, this can take up to an hour. Good luck!
Jul 10, 2014 | Hoover Ultra U6430-900 WindTunnel Bagged...
Why does my Vacuum shut off!
Has this happened numerous times? If so, and the filters (all filters) are thoroughly cleaned then its possible the thermal protection circuit could be worn out in the motor. If not, it could be an assortment of other issues. Could you please provide more info?
Jun 17, 2014 | Panasonic MC-V7312 Bagged Upright Vacuum
Sticker wore off on the filter. which button backwashes? the pool is about to overflow.
b> VALVE SETTING FUNCTIONS OF VALVE POSITIONS FLOW DIRECTION THROUGH VALVE FILTER PUMP - TOP - THROUGH FILTER - BOTTOM - RETURN For normal filtration and vacuuming pool through filter. BACKWASH b> PUMP - BOTTOM - THROUGH FILTER - TOP - WASTE For reversing flow for cleaning filter. RINSE b> PUMP - TOP - THROUGH FILTER - BOTTOM - WASTE For initial start-up cleaning, plus resetting filter bed after backwashing. WASTE b> PUMP - WASTE For vacuuming directly to waste, lowering pool level/draining pool. CLOSED b> NO CIRCULATION PAST PUMP PORT For shutting off all flow to filter and pool. RECIRCULATE b> PUMP - RETURN For bypassing filter, but circulating pool water. May be plumbed for "off-system" pool water access. Ideal for Jet-Air® fittings. WINTER b> VALVE NOT IN USE
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 28, 2011 | Hayward SAND FILTER, PRO SERIES
My Jandy Laars Natural Gas pool heater (LJ250N)
Check your heater by-pass valve and be sure it is almost closed. If not that then it will be your internal by-pass. These will force water through heater and keep it from overheating the water inside it and shuting it down. Also check to be sure the baskets are clean and the filter is clean.
Jun 27, 2010 | Zodiac Jandy Lite 250K Btu Natural Gas...
The dryer keeps shuting off and saying check filter
Check the rear exhaust vent at the bottom back of the dryer. If it is clogged it can cause the dryer to "overheat", that is ... if the vent is clogged with lint and debris a fire could start if there was enough heat.
Please rate this answer for me. Thank you
Mar 26, 2010 | LG DLE5977 Electric Dryer
R70ct ready heater keeps shuting off
either you have debris in the fuel line or you need to clean the igniter
Feb 01, 2009 | Desa International R40 Utility Heater
Pool & Spa Logo
51 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
