Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
My washer wont start it just gives an E inthe display
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Try pressing the pause start button holding it for a few seconds, also check door is closed with no washing trapped
Posted on Jul 18, 2009
Where is the fuel cut-ofF
THE SWITCH EITHER BEHIND ONE OF THE KICK PANELS INTHE FRONT OF CAR OR INTHE SIDE PANELS INTHE REAR NORMANLLY IT WILL HAVE A PUSH BOTTON ON TOP TO RESET IT
Jun 06, 2015 | 2007 Hyundai Getz 1.4
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
Memory card has a problem after taking important pictures.. displays reinsert memory stick error and wont read on computer either... any idea if photos can be recovered?
Make sure the memory contacts show up a visible clarity. If there is no detection in any of the card readers, inthe camera and inthe PC, it seems likely that your card has some errors on it,
If the card is detecting the memory but is not showing any pictures, the use a file search in the search mode with the drive selected for pictures/images.
If not it will be best to have it checked with a photo studio to concur the findings since you have important images on it.
Sep 23, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tv wont turn on
The TV has probably failed inthe power supply which is a SMPS unit.
You can check my link which gives some details to check SMPS units.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 14, 2010 | Polaroid TLA-01511C 15 in. LCD Television
It won't start lights blink it beeps no water goes in and it won't start.
the hose in back that goes to washer may have sediment in screen that need to be cleaned check were they hook up to washer i dont thank its the selenoin that let water inthe machine ,also are the water vales on?
try cancel then try another cycle.
Dec 22, 2009 | Frigidaire ATF6000ES Front Load Washer
When iturn on the comouter the screen is blank
try connecting an external display and switching the image to that one. if that works, you know it's your internal display. if it gives the same blank screen, it most probably is the graphics adapter on the mainboard.
May 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
165 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
