Question about Sanyo DS27910 27" TV
Only get a line acrose the center of screen how can I corect it
    Sergeant:
    Champion:
  • 212 Answers
It was a problem in LCD pls check with the sanyo service center
Posted on Jul 18, 2009
Getting vertical yellow lines on tv. It's two years old
This is a problem with the screen tabs( where the screen electronics bonds to the screen) it can often be corected by compression tabs but it will need to go to an engineer
Jan 03, 2016 | Samsung UN50F6300AFXZA - UN50F6300AF 50...
Have vertical coulerd lines all acrose sceen
This could quite easily be your T-Con board.
The simple way to go about things, is open the unit up. obviously with power off and having grounded yourself first.
1. Dust off everything
2. Check main board for any capacitor issues.
3. not serial numbers and any other numbers you see on your main board and T-con board.
4. search youtube or internet for how to vids for your model of tv
5. if you discover that the problem is related to t-board, which it sounds like it is, then order new t board and replace.
6. Not hugely difficult. Just remember where all the screw go and don't get your screen scratched in the process.
Jan 16, 2015 | Samsung Televison & Video
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Line acrose tv and only two colors the top and bottom are ha;f moon shape
Convergence is dead.Must know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts,and labors.
Mar 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Just a line acrose tube has audio. looks like it is all there but in a compack line.
Hi david
To answer your question;
What you have is a vertical problem(no deflection vertically)
If not caused by bad solder joints on the vertical output i.c then the output itself maybe gone.
Try to knock on the side of the tv as it may come back temporary, indicating a bad connection.
Hope this will help good luck
Feb 20, 2010 | RCA Televison & Video
When I turn on my laptop, I can hear it working but only see colored lines across the screen (no image). After tapping it a hundred times, the image comes back but the computer is so sensitive that heavy...
Probably a loose connection on the wires from the mainboard to your monitor.
Either disassemble the laptop yourself and corect the problem or go to a service center and ask a pro to do it for you.
P.S. If that's not the case than you may be looking at a damaged screen/mainboard - in both cases a visit in a service center will help.
Nov 10, 2009 | Lenovo R61 T7300 Notebook
Clean the screen of my Nokia E75
carefully unscrew the panel first with corect type of screw driver remove it carefully clean the face plate an fix it back if you have any fear do that take to nokia service center they will do it withe free of cost..thats all
Oct 20, 2009 | Nokia E75 Cell Phone
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS27910 27" TV Logo
57 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
