Question about Directed 434MHZ Remote Control
Lost TV remote while on alternate INPUT
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Samsung TV. When I moved I disconnected it while it was on an INPUT other than regular cable. I lost the remote in the move. I purchased a RCA universal remote but cannot get the INPUT back to cable TV. I can get the TV to turn on and off but not change INPUTs. Can you help?
Another expert site answered my question. Since there was no INPUT button on the TV, I need to buy an original remote.
Posted on Jul 19, 2009
I accidentaly disconnected my Samsung 60" tv picture when I tried to move the tv to watch it from a different angle in the room. Everything else is still working but no picture?
You might want to check what got disconnected. If it was an HDMI cable to your cable box, Either the cable or input port on the TV could have been damaged. Try a new cable and possibly a different HDMI input port. Also try watching a DVD through the same port to see if the input is OK. If the above doesn't work, check that you can at least bring up the setup menu on the TV. No menu could indicate a damage display panel or driver...
Feb 02, 2015 | Samsung Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Samsung lw20 lcd tv white image
Hi same here
The cables want to be in their correct place. After you have made sure that the cables and plugs are in their place. Check the input on the remote control. If your connection through the antenna and the the remote does ot show that,move to the antenna input.
The same method goes for the HDMI or ADSL Broadband or what.
Move to the correct input. OH and another matter, check that the scart plugs are iwhere they should be.
Good luck
kolbrun
Apr 15, 2012 | Samsung LW20M21C 20 in. LCD Television
NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE THE MUTE OFF. TRIED WATCHING DVD, WORKS FINE WITH SOUND, THEN BACK TO CABLE, NO-SOUND. PLEASE HELP! TV IS SAMSUNG
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Jun 30, 2009 | Samsung LN37A530 37 in. LCD HDTV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Panasonic SC PT660 Theater w Samsung Plasma -No sound w/Aux Input
My best advice is to do a factory reset on the system and then set it up again like you did when you first installed it. Unless your daughter physically damaged cables, the system should work OK. It's no use trying to work out what she disconnected as that will take even longer than a factory reset.
May 27, 2017 | Panasonic SC-PT660 Theater System
I have a samsung tv and I lost the remote and cannot change input
You may have to order an original go to www.sears.com ...the paret dept and have your make and model ready!
This should fix ya
Dec 12, 2008 | Samsung CXJ1364 13 in. TV/VCR Combo
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
Help with getting to video
TRY THE SAMSUNG CODES for any universal remote
Oct 15, 2007 | ESA EF402E 20" TV
TV
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
Aug 09, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Televison & Video Logo
139 people viewed this question
Top Directed Televison & Video Experts
ted dux
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
