Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Red light when turned on tv made a slight scratching noise and will not turn on. The light that is normally green flashed green/yellow then turns to red
    Problem Solver:
  • 8 Answers
Sounds like its time to look into getting a replacement bulb.
Posted on Jul 18, 2009
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
Dec 26, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Ps3 will not turn on properly
You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the PS3 yellow / red lights flashing problems after bought this guide. It's Video and Guides are really catch your eyes and fixed many PS3 issues ! The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Yellow Lights Fixing Guide
May 30, 2010 | Sony Playstation 3 (PS3) Console
Tv doesn't work
If this TV has a lamp it could be it. I need the model number to better figure it out
Mar 08, 2010 | Televison & Video
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
Akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
TV has sound but no picture
It is possible one of the internal fuses blew out.
It could be a bad horizontal outut transistor.
It could be a bad secondary of the power supply went bad
And many other things.
If it's just a fuse, it won't cost much, but a lot of them do not look like you would expect a fuse to look like.It might be a little yellow, green, or gray rectangualar box shaped part. :D
Dec 16, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
99 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
