Question about LG WD-12126RD Front Load Washer / Dryer
How do i unlock the door of my lg washer? - LG WD-12126RD Front Load Washer / Dryer
LG WM1832 CW how to force unlock the door
look to the bottom of the washer some may have a drain plug next to the filter placement as to the LG TROMM washers....do have a bucket ready as it will come all out at once if ya take the filter cap off
Oct 04, 2016 | LG Washing Machines
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
My LG machine shows dE as soon as I start it. The lid is closed. What to do?
Check the owners handbook if you have it. If not go online to the main LG website find manuals and download one. Have your model and serial number ready, these are on a sticker on the back.
Mar 30, 2015 | LG Washing Machines
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
The door not unlockings
Front loading washers have a safety feature to lock the door during washing. Try turning the power off to see if the door can be unlocked. But first, try applying a little more pressure to open the door. Pressures from washing may have sucked the door in and formed a seal.
Regards
Mar 06, 2011 | LG WD14121 Front Load Washer
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG Front Loan washing machine
If your LG is similar to mine, there could be water in a hose that is located behind the small door on the bottom front of the washer. Open the door and drain the hose. Be sure to have a bowl or pan to let the water run into. Once the water is drained hopefully the washer door will open. When i brought my washer this was one of the selling features the sales person told me about.( The door and hose are accessible to the consumer to prevent them from having to call for a repair) Hopefully this will be your only problem. I bought an LG washer on June 28, 2008. It is now August 21st and my machine is still broken. It broke the FIRST time I ever used it (July 13th) and it still has not been repaired. (Per the repair person it is a water sensor problem which has been "ordered") I wish I had purchased another kenmore instead. I had my kenmore 16 years and never ONCE has a problem with it. I simply wanted to update my laundry room. WHAT A MISTAKE for me to purchase LG!!!!
Aug 12, 2008 | LG WM-2277HW Front Load Washer
Fron t Load washer will not unlock
Usually, the door will not unlock because there is water still inside the unit.  You will need to get the water out of the tub to get the door to open.  On the bottom left corner, there is a small door.  Inside the door is a small rubber drain hose.  This will empty out the water inside.  After awhile, the machine will unlock the door.
Jul 06, 2008 | LG WM-1832C Front Load Washer
LG WD-12126RD Front Load Washer / Dryer Logo
1,883 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
