Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
No green light....no chlorine generation
Same problem as you......no green light....no chlorine generation ....everything else appears exactly normal.......metal plates are clean and the plate terminals are showing around 60ohms (not sure if i'm reading that right) --- Thanks
  • 297 Answers
Make sure you have at least 3000ppm of salt content'
set your timer for generation - the green chlorine light will not come on for at least 5 minutes sometimes up to ten
make sure you run the generator for at least 4-6 hours the first time
Posted on Jul 21, 2009
I have a cell t15. everything seems to be running normal, no error message on the panel but not generating chlorine. Salt is at 3000 ppm. everything seems fine but no chlorine even at super chlorinate
check at union of cell loosen union a little so drips check with strip if no chlorine not working if shows chlorine need to super shock pool its using chlorine as it makes it
May 05, 2018 | Pool & Spa
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
I have set up the intex saltwater system. We have run the salt generator for several hours, however the chlorine reads 0. I have added conditioner (thinking this was the issue), however, everything else...
The short answer is add some chlorine. Clean your cell and assure it is operating normally per you owner instruction. Normally, the manufacturer recommends physical cleaning followed by acid wash. Of course use the usual safety precautions when using muratic acid.
Conditioner? Is that Cyanuric Acid? or is this a sequestering agent for removing metal?
Thanks for your interest in FixYa.com
Jul 03, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
Intex chlorine generator no working
check sensor if ok cell or check voltage to cell
Jun 14, 2017 | Intex Automatic Salt Water System for ...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
No light on cell status on my chlorine generator
What brand of salt water chlorine generator do you have?
Have your water tested professionally at a pool store. Balance the pool water chemistry. Check the electrolytic cell for any calcium deposits on plates and follow manufacturer's instructions to clean.
Mar 18, 2009 | Pool & Spa
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
605 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
