My Hard disk (Hitachi) delayed in opening and not working propably !
i belive that it got infacted by some vairus. Can you Help me in this problem please ?
Thank you in advance
Comments:
Nov 20, 2007
- My Hard disk (Hitachi) Before today was working and it show tow partion almost full now it show only one partion and it is delayed in opening and not working propably the second partion it is not opening and seem to be empty of data though it is almost full ! i belive that it got infacted by some vairus. Can you Help me in this problem please ? Thank you in advance
Delayed opening issue of your hard disk was not being affected by a viruses. It is a hardware problem. Your problem sound bad cluster. If you are using Windows XP try to defrag it by using deframentation system.
You can access that by the following command or procedure. Click Start> Program> Accessories> System Tools> Disk Defragmenter.
After opening the system, select the hardrive detected and click defragment.
Defragmenter are working to fix any bad cluster available just leave it while waiting until done.
If you found problem such bad cluster, and already fix it. Please let me know and rate my solution SOLVED.
Thank you.
Philip
Comments:
Nov 20, 2007
- You can use disk management, goto start>control panel>administrative tools>computer management>disk management> If two partition visible it means it is being unlocked by the system cause of disk full already. Just highlight the drive available then right click and explore inorder to see the file inside.
If not try to use data recovery but it seems you need to spend money cost $99. I can give you the software but I only need chat session to give you complete instruction.
HI, CAN COPY PHOTOS ON MY technika digital photo frame BUT WHEN I TAKE THE CARD OUT THE PICTURES...
(More)
HI, CAN COPY PHOTOS ON MY technika digital photo frame BUT WHEN I TAKE THE CARD OUT THE PICTURES AREN'T THERE HELP !
