Question about Ace Hardware Hunter& Low Profile III Ceiling Fan
My Hunter PGM sprinkler heads are stuck in the same position. Any way to fix this?
  • 3 Answers
Hunter has released the PGJ sprinkler, a direct replacement of the PGM series. With a rubber cover and the smaller PGP type gear drive, the PGJ series rotor should solve your issue. I would look at www.hunterindustries.com and find a wholesaler near you for costs of replacing your PGM sprinklers.
Posted on Jan 12, 2010
Hunter xc sprinkler manual
pl change ur Remote crystal may b solved ur problem
May 27, 2014 | Hunter Televison & Video
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Nelson solorain 8014 manual
Buy a new timer. Sounds like the circuit board has a short. or call the manufacturer number should be in the instructions.
May 18, 2013 | Signature Control System Signature 77516...
My hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Oct 22, 2011 | Nelson Sprinkler: Traveling Tractor
My Hunter PGP ADJ Sprinkler Head will no longer move (turn in an arc)
Once a PGP stops rotating, it must be replaced. The gears that drive it are not replaceable.
Gary ( a sprinkler contractor)
Apr 27, 2011 | Garden
Hunter XG sprinkler timer not working
https://www.hunterindustries.com/sites/default/files/OM_XC_EM.pdf
https://www.hunterindustries.com/sites/default/files/LIT-397-RevG-OM-X-CORE-EN-web.pdf
REPLACE the alkaline battery can be used to program the controller in the absence of AC power. Even without a 9-volt battery the EC will keep track of time for up to 1 month and retain the program indefinitely in the event of a power outage.
Oct 06, 2017 | Hunter Ceiling Fan Control Switch
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Hunter PGP Sprinkler Problem
For a small price, it's worth it to replace it with another Hunter PGP. Don't settle for cheaper products as the PGP is the best in the industry, bar none.
Jul 09, 2008 | Ace Hardware Hunter& Low Profile III...
Hunter sprinkler head adjusting...
I googled Hunter sprinkler heads and where to purchase them. In my area (the East bay, Tri-Valley) in Nothern California.
I went to Ewing Irrigation in Dublin, CA and found the Hunter sprinkler heads there. The man working the counter got two for me and he demonstrated how to change the head by unscrewing it from the base at or just below ground level by removing the old one and screwing in the new head. He also showed me how to adjust them with the spray pattern. You will need the little tool that comes with the sprayer head.
Making sure the center arrow is completely to the left and rotate the head to the right then back to left. They are set to a 180% spray pattern from the manufacturer. If you want a bigger pattern you turn the adjuster toward the ( + ) side and if you want less pattern you turn the adjuster to the ( - ) side. He showed me how to install the red sprayer inserts by simply pushing them in the cavity making sure the little u shaped indentation is pointing up to allow for the set screw to go through to adjust the spary.The spray varies in distance and amount of water being emitted from the head depending upon the insert used.
I was able to replace the Hunter head, adjust the spray and changed out the insert a few times until I found the one I liked. I used needle nose pliers to remove the initial spray insert that the man @ Ewing installed until I found the one that worked best.
I found using needle nose pliers makes it very easy to grasp the little inserts for replacing.
-Terry
Apr 04, 2008 | Ace Hardware Hunter& Low Profile III...
Ace Hardware Hunter& Low Profile III Ceiling Fan Logo
2,361 people viewed this question
Top Ace Hardware Dryers Experts
Are you an Ace Hardware Dryer Expert? Answer questions, earn points and help others
