Question about Refrigerators
We have a kitchen aid superba 48 unit side by side both units have no power powe has been checked and it is coming in ok
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com
Here are a list of outlined problems that commonly come up under the circomstances you have described.
Faulty Defrost Timer / Control
Some models use a mechanical timer while others use an adaptive control which is a computer board. Regardless which device is used, the purpose is the same. The defrost control is used to send power to the defrost heaters at the proper time. If power is not reaching the the defrost heater circuity, it is most likely the fault of the defrost timer/control mechanism.
When the defrost timer is in the defrost cycle, the compressor and fans will cease to operate. If the timer fails to advance from the defrost cycle, the machine will not operate. Mechanical style timers can be manually advance both into and out of the defrost cycle.
Faulty Cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been acheived. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
Compressor and lights both operate
Defrost Problem
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal.
Dirty condensor Coil
Check the condensor coils for lint and restrictions. It is located underneath the refrigerator and accessible from the rear. A dirty condensor coil will result in poor cooling, especially in the freezer.
Low Refrigerant Charge
If the unit has a low refrigerant change, the freezer will not reach proper temperatures. This must be checked by a qualified technician due to EPA regulations.
Faulty Condensor Fan Motor
The condensor fan motor is found under the refrigerator near the compressor. This motor is essential to proper cooling. If the fan motor is not running, there will not be proper heat removal from the condensor and the result will be higher than normal temperatures in the freezer and usually in the fresh food section. Ensure the fan motor is running when the compressor is on.
Good Luck
God Bless
Posted on Jul 18, 2009
Water leaking under kitchen aide refrigerator
Could be condensate from the refridgeration unit or the icemaker water connection if the refridgerator has one
Oct 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
Problem with kitchen aid superb side by side refrigerator - ice will not dispense. It makes ice, and the water works just fine. Is there are part that I can by to replace the door insert all together?
This is the auger, the unit that dispenses the ice. Check to make sure that the power to the unit, usually plugs into a port in the freezer, isn't dislodged or loose, If that doesn't fix the problem, you can call local part sellers, you can find one on www.whitepages.com, and see how much for a new or reconditioned one.
Hope this helps
Joe
Aug 29, 2011 | KitchenAid Superba Architect KSCS25INSS...
My kitchen aid Superba 48 the meat drawer is broken and I need to replace it. Does anyone know were to buy the drawer?
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
Nov 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aide Superba 48 1997, refrigerator door remains ajar,Fix?
They actually make a guard that acts as a height shim. You do need to remove the door to install it though. Try looking at appliance411 they usually have some insight into out of the ordinary parts. Hope this helps. Good luck.
Aug 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
