Question about MSI MEGA 865 (MCM865) Barebone
Msi mega desktop wont boot, when holding the power button the fan will run for about 10 seconds, if holding power button and pushing reset button sounds like the hardrive runs for about 3 seconds
  • 23 Answers
Check power supply is fixin to go out
Posted on Jul 18, 2009
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
Push button is always stuck on the fan runs on high speed will not boot
yes will not boot because the power switch button is always contacting to switch. is like a long press about 3 or 5 seconds it can be turn off the system. remove the front cover clean the push button power switch housing and apply lubrication such as grease or oil.
Oct 11, 2009 | Everex GA3400 PC Desktop
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Jun 22, 2009 | Gateway GT5220 PC Desktop
Acerpower SV PC will Not turn off
More information would help to resolve this issue.
Are you shutting down by selecting Start and shutdown or have you tried pushing the power button on push (not holding the power button)?
Try this:
Press and hold the power button in solidly for about 10 seconds. If it shuts down before you get to 10 just let off the power button. This should work, but may not solve the problem.
If you reboot it and still can not shut down from Windows, hold power button until it shuts down, unplug the power cord and disconnect everything from the computer other than the keyboard, mouse and monitor. With the power plug still unplugged, hold the power button in for about 15 seconds (this resets the power supply and can clear a corrupt BIOS).
Reconnect power and after booting, see if you can shut down from Windows.
If still no go, click Start, Programs, Accessories, System tools and select System Restore.
Follow the prompts and select a bold date back to a time before you had problems shutting down. That should do the trick.
Let me know if you get it fixed or if you need more advice.
Honest1abe
Jan 02, 2009 | AcerPower SV PC Desktop
Mac laptop
you can try to take off the battery for 24 hours at least, then put it back and switch on
Sep 07, 2008 | Apple MacBook Mac Notebook
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
MSI MEGA 865 (MCM865) Barebone Logo
139 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
