Question about RCA P52960 52" Rear Projection Television
NO VOLUME ON MY RCA P52960 52 in.
Does anyone know how to repair this? I turn it on and I hear a distinct audio click and if I hold the volume button down, it clicks repeatedly.
Anyone out there know what to do?
  • 61 Answers
Re: NO VOLUME ON MY RCA P52960 52 in.
Sounds like you need to unplug the set for about 5 min. and let it reset,this should return your sound
Posted on Mar 07, 2008
0 characters
3 Points
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Well I have a problem with the audio of my JVC AV-48WP30 48 I have dish network and when I turn on the t.v. I ca't hear looks I try to up the volume and the t.v shows the littles lines of the volume but I...
Try rebooting the dish network box hold down the power button on the box for 20 seconds then let it go. When it gets through rebooting see if your sound came back.
Nov 13, 2009 | JVC AV-48WP30 48" Rear Projection...
RCA 52" projection P52920BL no volume, if you turn it up can hear speaking chirping
check the back of set to see if there' an internal external speaker switch- also check on screen audio menu to see if speakers are set to off
Oct 18, 2009 | RCA P52920BL 52" Rear Projection...
RCA Projection TV P52960
The clicking repeatedly is the relay clicking on and off due to the power button being pushed in. You are having problems with the start up circuit. Probably minor but you would need a service manual to actually diagnose the problem . Let me know if you would like me to post a link where you can get the service manual
Nov 19, 2007 | RCA P52960 52" Rear Projection Television
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Power, volume buttons
Is this on the remote or the buttons on the TV?
Aug 17, 2007 | RCA P46810LV 46" Rear Projection...
Hitaci volume problem, pls help !!
My problem is solved. There is a separate volume control on my HD cable box that had been turned down. By turning it back up the issue was corrected.
Jun 18, 2007 | Hitachi 53UWX10B 53" Rear Projection...
RCA P52960 52" Rear Projection Television Logo
59 people viewed this question
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
