Question about Refrigerators
When the refrigerator finish cycling, the compressor shakes and rattles. What is going on?
  • Refrigerators Master
  • 1,606 Answers
Inside the compressor , the motor is held by 3 or 4 springs . When 1 of those springs break (either from rust or time) the internal motor will bang the inside of the compressor . This does not mean the compressor will quit , only noisey when cycling off . Only way to stop the noise is to replace the compressor OR try shimming up one of the compressor mounting legs (will take trial and error to determine which leg will stop the banging ) . Always reinstall the rear cover even when checking .
Posted on Jul 19, 2009
Top refrigerator rattling inside the refrigerator when first starts to run then stops rattling
There is something loose, when first starting the compressor because of its initial load vibrates shakes etc then settles down as the system stabilizes. Move things around inside and see if this helps. If not remove everything and try again, if the rattle is still there it is part of the cabinet, if not it was something inside.
Jan 31, 2016 | Kenmore Refrigerators
My refrigerator is plugged up to the wall but not cooling or freezing
Hi, You may have defective compressor / motor or thermostat. Please check it out.
Jan 23, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
I opened the refrigerator and its no longer cold in there, both sides.
Greetings,
The first thing is to determine if the compressor is running...if its off and not running..remove rear cover...if you hear a clicking noise once every five minutes or so...The relay may be bad...this is the part that fits on compressor terminals. remove it and shake it..if it rattles...its bad, it could even be bad and not rattle, but they usually burn out and rattle...okay, now if compressor is cold and nothing comes on..it could be off thru the defrost control or thermostat. I'm betting , its a burned out relay
Jan 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not cooling at all, fans all run, compressor is warm and you can hear the thermal click on it every once in a while. Possibly the starter capacitor?
Greetings,
remove the relay and shake it..if it rattles, its bad...replace it and all is well.....however, if the compressor is bad..it will cycle on thermal as well.
Jan 12, 2011 | Maytag MSD2351HE Side by Side Refrigerator
Jenn Air - JCD2389GES Side by Side - Freezer cold, refrigerator not cooling. No real frost buildup in Freezer - took back panel off and no frost on coil... Compressor is very warm. Fan is blowing on...
Sounds like a bad overload/relay . On the compressor , with the refrig unpluged , pry off the box on the side of the compressor with 2 or 3 wires going to it . If you have a meter that beeps on the continuity setting , touch the 3 compressor pins 2 at a time . If no beep , compressor is bad . If a beep from either of the 3 pins to the copper lines connected to the compressor , then the compressor is shorted . If all 3 pins beep , replace the overload/relay pt # 12002784 .
NOTE : if you do not have access to a meter , shake the relay ( black piece ) and listen for rattle noise . If rattles , its bad .
Sep 27, 2010 | Refrigerators
My refrigerator has a loud rattle in back when the compressor (i think) shuts off. when i pulled fridge away from wall i can simulate the noise by shaking what looks like an expansion tank. Sounds like a...
more than likely you probably have a bad compressor foot mount . It is a rubber cushion between the compressor and the refrigerator base frame. they wear out, allowing the compressor foot to contact the mounting base which would be metal to metal contract.
Mar 13, 2010 | Refrigerators
MODEL# ARB2557CSL STARTED MKING CLKING NOISE TWO
Hello, this problem is going to be with the relay on the compressor or the compressor. Pull the refrigerator out and remove the bottom panel off the lower rear of the appliance. Behind the panel you will see the compressor. On the side of the compressor you will see the relay cover. remove the cover then pull the wire harness off. next give the relay a tug and it should pull off. Once you have the relay in your hand give it a shake. if the relay rattles then your problem is the relay. If the relay does not rattle then the problem is with the compressor. You should call a service guy. If you have any additional questions please feel free to comment. Mike
Dec 10, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Refrigerator not cold. The motor is blowing but
unplug the refrigerator. get to the compressor remove the cover on the compressor, remove the brown or white relay. the compressor also has an overload, but that maybe on the top or connected to the relay. remove the wires, remember where they go, shake the relay, if it rattles it's bad. you will need to get a solid state relay to replace the bad one..Good luck
Aug 29, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
Freezer not freezing, everything is thawing.. only 3 yrs old, refrig part only 47 degrees
sounds like your compressor is not starting up. unplug your refrig then remove the start relay from the side of the compressor. shake the relay if you hear alot of rattling around in the relay then most likely that is all thats wrong. if it doesnt rattle alot then possibly the compressor is locked up and is bad.
when you shake the relay if its broken internally usually little peices of ceramic will fall out of it. so shake it over a peice of paper to see if that happens/..
Dec 16, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
