Car Audio & Video Logo
Matthew kever Posted on Sep 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I bridge a power acoustik ov4 - 840 in bridged node
bigdawg7299
Level 3:
  • Master 2,559 Answers
  • Posted on Sep 02, 2016
bigdawg7299
Master
Level 3:
Answers
2559
Questions
0
Helped
556849
Points
7776
Google your model number or go to www.poweracoustik.com and download the owners manual. You can bridge it to 2 channels 4 ohm stable only!
4 Related Answers
Anonymous
  • 655 Answers
  • Posted on Jul 26, 2009
SOURCE: when I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
I'd suspect that the amp is operating into too low of an impedance and going into protection.
The 2200/2 is not rated to drive a 2ohm load when bridged (most 2-channel amps aren't) and when you connect 2 4ohm subs in parallel, the load is 2ohms. I'd run one sub from each channel.
Hope this helps.
Anonymous
  • 6 Answers
  • Posted on Nov 26, 2009
SOURCE: how to bridge a 4ch power acoustik amp to 2ch
I had the Power acoustik saphire 4ch and had to do the same thing. Use the Positive from Term1 (spkr1) and Negative from Term2(spkr2). Good Luck.
skinnman33
Mark Skinner
  • 79 Answers
  • Posted on Dec 22, 2009
SOURCE: Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on FixYa.com. Thanks!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Anonymous
  • 443 Answers
  • Posted on Jan 28, 2010
SOURCE: i have a power acoustik 0v2-300 2 channel amp i
Most amps will show right on the amp by the speaker wire terminals if it is bridgeable.
Good luck !
How do I wire a Power Acoustik MSA4-1300D Amp to a single subwoofer?
It depends on how many channels are on the Amp. If it's a 2 channel you can bridge it using the positive on one channel and use the negative on the other channel. The Amp will give the sub more power bridging the sub.
How do i find how many ohms my amp is because i cant find it here the name of my amp is poweracustick lt 980-2 of 980 watt i want to know that so i know what speaker to hook up with
According to a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
I have a power acoustik 0v2-300 2 channel amp i just wanna know can i bridge it
Good luck !
I have to bridge my subs because the one channel isnt working
Did you check the fuse?
If you have a bad channel I wouldn't suggest bridging I would look into getting it fixed or using the remaining functioning chanel.
Cheers
How to bridge a 4ch power acoustik amp to 2ch
1helpful
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Lt960-4 power acoustik Amp 4 channels mono
it can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
1helpful
3answers
When I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
Hope this helps.
2answers
Power Acoustik Area 51 Amplifier
I havthe same amp. Try moving youry ground t a different location. that seemed to help me when i was brigging mine.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
