Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
