Question about Acer Aspire 9410 Notebook
It heats up to the right side, especially when i leave it for a long while on my desk without air conditioning or ventilator
    Problem Solver:
  • 15 Answers
Your processor is located on the back right side. The heat is generated from the heatsink/fan inside of the case.
Posted on Jul 18, 2009
Olds bravada only blows hot air
Is yours manual or Automatic HVAC system ? heating ventilation air conditioning . When is the last time you tried it ? did it work then , last year ? Where do you live south , north ? Have you had any refrigerant added lately ?
The Heating, Ventilation and Air Conditioning (HVAC) system is divided into three separate sections. The first, Heating, Ventilation and Air Conditioning, has all procedures that pertain to a HVAC component or function that is not specifically associated with the manual control system. The second, HVAC Systems-Manual, has all procedures specific to the manual control system.
Begin the system diagnosis with the:
Symptoms - HVAC Systems - Manual in HVAC Systems-Manual for 4.3 L without DTCs
Diagnostic System Check - HVAC Systems - Manual in HVAC Systems-Manual for 2.2 L with DTCs
Diagnostic System Check - HVAC Systems - Automatic in HVAC Systems-Automatic for 4.3 L with DTCs
The Diagnostic System Check will provide the identification of the control module(s) which command the system.
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Review the Description and Operation information to help you determine the correct symptom diagnostic procedure when a malfunction exists. Reviewing the Description and Operation information will also help you determine if the condition described by the customer is normal operation.
Apr 13, 2015 | 2001 Oldsmobile Bravada
08 dodge nitro blows hot air on passenger side but cold air out the drivers side!! Any answers
NOTE: LHD model shown. RHD model similar. All vehicles are equipped with a common heater, ventilation and air conditioning (HVAC) housing assembly (1). The heating-A/C system combines A/C, heating, and ventilating capabilities in a single HVAC housing mounted within the passenger compartment behind the instrument panel. The HVAC housing assembly includes:
  1. Mode-air doors (2)
  2. A/C evaporator (3)
  3. Recirculation door actuator (4)
  4. Air inlet housing (5)
  5. Recirculation-air door (6)
  6. Blower motor (7)
  7. Blower motor resistor (8)
  8. Heater core (9)
  9. Air distribution housing (10)
  10. Blend-air door (11)
  11. Blend door actuator (12
  12. Floor distribution ducts (13)
  13. Mode door actuator (14)
Jan 28, 2015 | 2008 Dodge Nitro
How can I leave the A/C running when I turn the egnition off ?
you cant the motor turns the ac compresser the fan uses battery/altinater power
Apr 28, 2014 | Air Conditioning and Heat for Audi Q7
What does the acronym HVAC stand for?
Heating Ventilation and Air Conditioning
Jan 30, 2013 | Heating & Cooling
What is hvac
Hi, Hvac that i know is (Heating, Ventilating, and Air Conditioning) refers to technology of indoor or automotive environmental comfort. HVAC system design is a major subdiscipline of mechanical engineering, based on the principles of thermodynamics, fluid mechanics, and heat transfer. Refrigeration is sometimes added to the field's abbreviation as HVAC&R or HVACR, or ventilating is dropped as in HACR (such as the designation of HACR-rated circuit breakers).
HVAC is important in the design of medium to large industrial and office buildings such as skyscrapers and in marine environments such as aquariums, where safe and healthy building conditions are regulated with temperature and humidity, as well as "fresh air" from outdoors.
Heating, ventilating, and air conditioning is based on inventions and discoveries made by Nikolay Lvov, Michael Faraday, Willis Carrier, Reuben Trane, James Joule, William Rankine, Sadi Carnot, and many others.
The invention of the components of HVAC systems went hand-in-hand with the industrial revolution, and new methods of modernization, higher efficiency, and system control are constantly introduced by companies and inventors all over the world. The three central functions of heating, ventilating, and air-conditioning are interrelated, providing thermal comfort, acceptable indoor air quality, within reasonable installation, operation, and maintenance costs. HVAC systems can provide ventilation, reduce air infiltration, and maintain pressure relationships between spaces. How air is delivered to, and removed from spaces is known as room air distribution.[1]
In modern buildings the design, installation, and control systems of these functions are integrated into one or more HVAC systems. For very small buildings, contractors normally "size" and select HVAC systems and equipment. For larger buildings, building services designers and engineers, such as mechanical, architectural, or building services engineers analyze, design, and specify the HVAC systems, and specialty mechanical contractors build and commission them. Building permits and code-compliance inspections of the installations are normally required for all sizes of buildings.[citation needed]
The HVAC industry is a worldwide enterprise, with career opportunities including operation and maintenance, system design and construction, equipment manufacturing and sales, and in education and research. The HVAC industry had been historically regulated by the manufacturers of HVAC equipment, but Regulating and Standards organizations such as HARDI, ASHRAE, SMACNA, ACCA, Uniform Mechanical Code, International Mechanical Code, and AMCA have been established to support the industry and encourage high standards and achievement.
Hope is the one your talking about.
Fill free to pass your comment...
Feb 14, 2011 | Cell Phones
Heat does not come out passenger side of the car but comes out drivers side
There is a blend door problem.
prev.gif next.gif HEATING AND AIR CONDITIONING Refer to Section 1 for discharging and charging of the air conditioning system. The heating system provides heating, ventilation and defrosting for the windshield and side windows. The heater core is a heat exchanger supplied with coolant from the engine cooling system. Temperature is controlled by the temperature valve which moves an air door that directs air flow through the heater core for more heat or bypasses the heater core for less heat. Vacuum actuators control the mode doors which direct air flow to the outlet ducts. The mode selector on the control panel directs engine vacuum to the actuators. The position of the mode doors determines whether air flows from the floor, panel, defrost or panel and defrost ducts (bi-level mode).
Oct 28, 2010 | 1998 Oldsmobile Regency
Laptop keeps turning off why?
This could be due to overheating. If you have ever taken a laptop apart then you will have seen that on most laptops the cooling fan draws in air via a grill and then blows this air around the CPU and exhausts to the outside world again. This air is NOT circulated around the rest of laptop case to dissipate heat.
You can try these steps
1. Check your power chord, socket, UPS, everything that leads from the electrical network to your AC power adaptor, but don't forget to check your BIOS settings and software setup, because it's probably your adapter who's sensing an overload of power drain
2. In most cases, an overheating processor due to a build of internal dust is the cause for random reboots or turn offs.
3. AC power adaptor not able to sustain normal power needs (faulty power adaptor) - take care of the same items as those I mentioned at 1.
4. Especially with older laptops, the battery may overheat, simply due to internal battery fault, or charging levels.
5. If you have a new laptop, be sure to have all ventilation openings free, and when used on a desk, try not to allow full contact with the surface - use a book or two to keep the laptop above the desk and have some space beneath it.
Regards
Aug 11, 2009 | Computers & Internet
How do I replace blower motor for heat and air conditioning, the blower is under the dash board
Removal Procedure
  1. Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
  3. Disconnect the electrical connector (1) from the blower motor.
  4. Disconnect the blower ventilation tube (2) from the module.
  6. Remove the blower motor screws (1).
  7. Remove the blower motor from the housing.
Installation Procedure
    Notice: Refer to Fastener Notice in the Preface section.
  1. Install the blower motor into the housing.
  3. Install the blower motor screws (1) .
  4. Tighten
    Tighten the screws to 1.7 N·m (15 lb in).
  5. Install the blower ventilation tube (2) to the module.
  6. Connect the blower motor electrical connector (1) .
  7. Install the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Jul 30, 2009 | 2002 Buick LeSabre
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Heating and air conditioning fan is intermittent
there is a fan resistor card in the evap housing(under glove box) that controls fan speeds
Jun 21, 2009 | 1992 Subaru Legacy
Acer Aspire 9410 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
