My window a/c is spewing little black flakes all over my white couch! Filter is clean. It's an older model Sharp Comfort Touch - very quiet, cools great!
  • 614 Answers
These flakes are from the blower wheel it gets mold and dirt and as it turn and gets moist it blows the out. Clean blower wheel wiht long soft brush and run unit put towel over open while running in fan only this will catch the extra dirt till clean Russs
Posted on Jul 18, 2009
I cannot get my coffeemaker to brew. Do i need to replace filter before it will brew, or clean with vinegar?
Run a couple cups of white vinegar through it (just like you were making coffee). Don't use a filter. You can use the same vinegar over again if necessary.
If calcium build-up is the problem, you will see lots of little flakes in the used vinegar. Continue running vinegar through it until you are sure the flakes have stopped, then run a couple full pots of water through it before you try making coffee.
Mar 10, 2015 | Coffeemaker Coffee Makers & Espresso...
The error code E1 is lit on the front panel of room air conditioner. The instuction book is lost and I can't locate the model number. It says energy star and comfort touch and come with an remote...
E1 is refering to the air filter. If turning the unit off and unplugging doesn't reset it then you probably have a PC board or sensor failure. None of these units can actually detect a dirty air filter. All it does is set a timer that turns the E1 on after what the manufacture determines is average.
Hope that helps.........
Jul 28, 2008 | Sharp Heating & Cooling
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
Turning off code e1 flashing what is e1 code
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
I have a kitchenaid refrigerator (Model KSRS25ILBL02). The water from the dispenser has some tiny white flakes. I though it's the water reservoir (100' coil tubing) problem. But after I took the...
have you ever changed the water filter that's in the front bottom sticking through the kickplate?part number 4396508 and it's around 45 to 50 dollars
Apr 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
Quiet cool emerson model 12G J44H black soot like stuff coming out of air conditioner--what is this and how can it stop? Does this window model have a filter? Thanks.
Sounds like your filter is coming apart. Take the unit out and wash it with a water hose. Clean it but try not to get water on the switches. Put it back in but do not plug it up immediately let it set for 15 to 30 min. I also use a shop vac to **** excess water ect... out of the unit after i clean it. good luck
Aug 09, 2010 | Emerson Heating & Cooling
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
