Question about Whirlpool LHW0050PQ Front Load Washer
I have a front-loader whirpool compact washer model LHW0050pq. Problem: After the done light turned on, I could not open the door. My failed solutions: 1) I've tried waiting longer, 2) unplugging and plugging the washer, 3) there is no water in the washer, so it did finish the wash/rinse/spin cycle properly. Still the door will not open. Any suggestions?
  • 1,000 Answers
It appears you have a mechanical latch for the door and one of the components is broken. You can try to pull the handle to the open position and look behind the handle and see if you can get a hold of the latch with a pair of needle nose pliers or a bent coat hanger. Pull the latch lever toward you to release the door. Once you get it open, do not close again. The latch will have to be fixed, replacing the broken mechanism.
If you are unable to get it unlocked that way, you can remove the top on the machine by removing the two screws in the back and lifting the top off. You can then go down through the top and release the latch and repair it.
Good luck, let me know.
Regards,
Posted on Jul 18, 2009
Front Loader Washer Cheap Parts I Need
Look on Craigslist or ebay for broken washers that are the same as yours (as long as they don't have the same problem) and purchase parts from it or the whole thing for cheap. Otherwise, some city's have appliance "junk yards" that you can get parts from.
Apr 29, 2012 | Whirlpool LHW0050PQ Front Load Washer
HOW TO INSTALL A BELT ON WHIRPOOL WASHING MACHINE LHW0050PQ?
Take the back off and the belt can easily be installed HOWEVER if the tub bearing is shot the belt will not stay on.
Oct 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
Washer will not tumble
I assume its a front loader. The first thing I would check would be the drive belt.
Control locked light on
First remove the plug for 5 minutes and this will reset the system.
Check to see if the light beside the LOCK ICON is lit on the status lights. If it is, then the controls are locked. Press and hold the OPTIONS and SELECT buttons simultaneously until the lock light goes out. This should free up your controls so that the washer will operate normally.If the console will not respond, then you could have a failed control or a stuck button.
Apr 03, 2009 | Whirlpool LHW0050PQ Front Load Washer
Very small space, limited choices
I would recommend whirlpool since they bought out maytag .They are a great for support and warranty:)
Mar 28, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Feb 19, 2009 | Whirlpool LHW0050PQ Front Load Washer
WILL NOT FILL
front loader has an error message f 3 and makes a noise from soap dispenser
Oct 28, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
