I parked it briefly with the engine running, brake on, blade off. It hummed along fine for a moment as I closed a gate. Then it died before I could get back to the mower. It would not turn over. Clearly no power going to starter motor. I can start it by shorting the two big lugs on the solenoid. Replaced the solenoid, but still no better. When it runs after starting by shorting the solenoid terminals, I must press the RIO switch to reverse EVEN if the blade is off. Also, getting off the seat kills the engine EVEN if brake is locked on and blade is off. Where is my problem?
Key switch may not be operating the solenoid for the starter. Getting off the seat engages a safety switch that kills the engine go you won't have to go chasing it if it were to slip into gear while you're standing next to it.
Testimonial: "Unhelpful answer. Oravetz provided no way to test his idea. Eight wires go to the key switch. A helpful answer would have told me which ones to jump to see if that is the faulty connection."
The safety switch beneath the seat is only one part of the several interconnecting safety features of the modern riding mower. If the system works properly, you must be seated for the mower deck to operate. The tractor will continue running with the Power Take Off disengaged if the parking brake is set before the operator leaves the seat.The seat switch consists of two electrical contacts normally separated by an air gap. A spring creates an open space between the two contacts. Mounted between two plates, the switch's spring compresses under the weight of the person sitting in the operator seat and completes an electrical circuit. With the switch closed the tractor's ignition system can be switched on with the ignition key. If the operator stands, the spring forces the gap open and interrupts the electrical ignition circuit. The safety circuit allows the riding mower motor to continue running if the PTO is not engaged. When the parking brake is set a second switch in electrical parallel with the OPS closes. This bypasses the safety switch under the seat. If the operator stands, the parking brake switch still completes the ignition circuit.The mower blade turns only when the PTO engages. If the operator should leave the seat with the blade turning and under power, injuries could result. The mower blade would even continue spinning at full power if the machine overturned. To prevent this type of accident, engaging the PTO deactivates a connection in the original circuit and completes a second circuit in series with the OPS switch.
If the operator leaves the seat with the PTO engaged, the ignition interrupts and the machine stops. Until the PTO is off, no combination of settings will restart the mower.
Call it Fixme. The problem was that the PTO safety switch had vibrated out of position so that the blade-engaging lever could not push it. Put it back in place with a superglued wedge.
