Question about Campbell Hausfeld 02-Gallon Air Compressor - FP2048
Will not build up pressure - Campbell Hausfeld 02-Gallon Air Compressor - FP2048
    President:
  • 1,273 Answers
You did not state whether the compressor would kick on automatically, or whether it would kick off at some point, so I have to work through it with you....
If the compressor runs, you should see pressure on one of the two gauges. The gauge that is closest to the tank is the pressure that the compressor proper is putting out to the tank, and is the primary gauge. The other gauge is the pressure supplied to the tool via the hose, downstream of the regulator. If you are seeing pressure at the first gauge, that's a good sign. Also a good sign is if the commpressor runs and switches off at some point before lifting the PRD (pressure relief device). This tells you that the compressor is pumping and that the pressure switch is working. If this is the case, try working the regulator control knob and watch the second gauge. The regulators can be tricky; sometimes the regulator knob operates in the opposite direction than expected, depending on the type of regulator, so experiment a bit. (Usually there is wording and an arrow on the knob telling you the direction to adjust. If you start to see a rise in the pressure on the gauge, go ahead and set the desired tool supply pressure.
If you can get a pressure on the first gauge, but nothing on the second gauge no matter how you manipulated the regulator, you should suspect a bad regulator.
If there is no pressure on the first gauge, try cracking open the drain valve on the tank and starting the compressor. If you get air out of the tank with no indication on the gauge, you should suspect a bad primary gauge. If you get no air out of the tank, open the drain valve further and check again. If still no air, the compressor itself is suspect. You will need to determine that the motor is in fact turning the compressor. If the motor is running, but the compressor isn't moving, unplug the compressor and reconnect the linkage. If the compressor will run with the motor, the compressor may be shot, or tha air intake may be plugged off. Remove the cover on the air intake and inspect the filter. Clean and replace as required.
If the compressor will start when you operate the on/off switch, but does not kick off at some point, the pressure switch is probably at fault. It is an odd piece of work....it is mechanical, electrical and pneumatic, all at once. You would need to troubleshoot each portion in order to put it right. The most common problem with the pressure switch is burned or welded contacts, followed by wiring issues to the contacts, then the air line to the switch, then mechanical linkages within the switch.
This humble guide should be enough to get you going. I hope that it has been useful.
Regards, and good luck!
--W/D--
Posted on Jul 19, 2009
Why In a re-built engine, oil pressure is not building up ?
How to build oil pressure before starting rebuilt engine? - D ...
www.d-series.org > ... > Engine Building
Feb 11, 2013 - 21 posts - ‎11 authors
As the title asks, how do you build up oil pressure in the d-series engine before attempting to start it ... My engine has been built for quiet a few months now, I did ..... If you have used a quality assembly lube, you will not have a ...
Running out of options: Rebuilt engine-no oil pressure ...
forums.pelicanparts.com/.../550050-running-out-options-rebuilt-engine-...
Jun 26, 2010 - In order to build some oil pressure I ran the engine. ... I am out of Ideas and do not dear to try to crank it over to build pressure. .... On my S2, it took me 10x removing the oil filter and filling up the center hole with oil and ...
rebuilt engine started but with no oil pressure ' DSMtuners
www.dsmtuners.com > Forums > General Tech > Newbie Foru
Dec 21, 2015 | Cars & Trucks
Pump builds pressure but not full pressure on same faucet iv always used
possibly have worn seals inspect them and also unloader valve which normally has a spring
Aug 13, 2014 | Craftsman 2700 Max Psi Pressure Washer 23...
Pressure not building in 1800 broaster
In order to build pressure, you need to first make sure that you have enough product to generate enough steam to build pressure. In a Model 1800 you need about 5-6 pieces of chicken or the equivalent to build a sufficient amount of pressure. You also have to have enough heat to create the steam, so check the oil temperature with a thermometer to make sure the actual temperature of the oil is close to the set temperature. If you have enough product at the proper temperature but no pressure is being generated, you need to determine where the steam is escaping. If the steam is escaping around the cover, replace the cover o-ring. If the steam is escaping from the exhaust stack in the back right corner of the unit, then your pressure regulating valve needs to be cleaned or rebuilt. The pressure regulating valve is mounted to the front of the cooking well just below the countertop. If the unit is several years old you should go ahead and get the rebuild kit for it.
Apr 09, 2012 | Kitchen Appliances - Others
My 1999 crown vic is still not building fuel pressure. I've changed the fuel pump and fuel pump relay still not building enough pressure. What else can i try
check or replace fuel pressure regulator. symtoms are. lack of fuel pressure, excessive fuel pressure, black smoke and engine running rich, instant drop of fuel pressure, when turned off delay building back up sufficient fuel pressure. also be sure fuel filter is not plugged. check the filter first !!
Oct 24, 2011 | 1999 Ford Crown Victoria
Air pressure only builds up to 45 lbs. compressor continues to run. I drained all the air and it still only builds up to 45 lbs.
The check valve is not holding the pressure back off the head,therefore allowing the pressure to build up fully.
Jan 04, 2011 | Air Tools & Compressors
Will only build pressure to 100psi of rated 140psi
Chances are that the pressure switch, were you turn the compressor on and off, is bad. When they go out, they no longer build pressure to the regulated level you are looking for. If you haven't already, try turning up the regulator, if no more than 100psi build's, then it's a sure thing, bad pressure switch.
Oct 11, 2010 | Makita MAC5200 Electric Powered Air...
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Nov 02, 2008 | Honda Garden
Vent Pipe Question
In the majority of buildings, yes - it depends on the type of building and the building regulations. The purpose of the open vent pipe is to relieve any positive pressure in the drainage system. In buildings up to ten storeys high, one open vent is recommended to relieve the constant positive pressure build-up that can occur if the main sewer is blocked for some time. In higher buildings the positive pressure generated is in transient form, so each stack would need an open vent.
Aug 27, 2008 | Elements of Design 1/2 Inlet Copper Pipe...
Campbell Hausfeld 02-Gallon  Air Compressor - FP2048 Logo
416 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
