Question about Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual
I have just purchased a Delta Rockwell Industrial Table Saw. It is a 1.5 HP, 3 BELT, 3 PHASE UNIT. How should I clean and lubricate the parts. I also bought 22OV 5 HP motor to put in it because I only have 220V SINGLE PHASE. The ripping guide is missing and the front round part of the fence housing is broken off. I have pictures of it. It is very heavy which I like. Thanks,Benson
    President:
  • 1,996 Answers
The table can be cleaned and waxed with a good quality paste wax like Trewax clear. If it has rust, you can use automative polish/cleaner and a rag or fine scotch pads to get the rust out, then wax the surface to protect it. Period waxing will maintain a low friction surface through use. Old timers used to recommend rubbing the bare steel table with talc to seal the pores, but I find was is more readily available and gives a better surface for use...Wax is also good on the moving parts of the fence.
The worm gears and trunnions can be cleaned with compressed air and regular 30w motor oil in a pump can. Maybe a soft wire brush or toothbrush if needed to remove built up resin and pitch. If there's a really heavy build up on the gears, get some OxiSolve bit and blade cleaner from Woodworker's supply and it will safely dissolve the gunk to a consistency you can scrub off with a toothbrush. I maintain these moving mechanical parts with oil, which an old pro recommended years ago, and have found it doesn't contribute to sawdust build up as you think it might, not nearly so much as an assembly lube or white grease, and makes raising and lower the blade a joy. If you're concerned about dryness, you can try triflow or some kind of bicycle chain lube, but I've decided the expense isn't worth the results, and oil is readily available when I need it...
If replacement parts are available for your model, try here. Otherwise, and for older machines, you might find a manual or parts info at this site.
After market fences are available for your saw, and depend on user preference. I've been very happy with my Biesemeyer fence, after using it (and many others) for 22 years. It is also heavy duty.
Posted on Jul 23, 2009
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
Sep 13, 2013 | Delta Rockwell 34-450 10" Tilting Arbor...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
The belt in the motor of my 10 inch delta table saw broke its a Bando synchronous 100XL belt...Think I can find a replacement...However, before it broke whenever I started the saw I noticed unusual sounds...
I have the delta 10 inch cabinet saw with the uni-fence, I bought just before somebody at delta smartened up with the left tilt blade, that is the worst design I have ever seen. I came real close to buying a Powermatic the same day I got this thing. Anyway, my saw sounds like a mack truck in reverse slamming the dump gate when it starts, I don't think there is anything to oil, it has bearings on the shaft. I found a ring of some sort on the floor one day that fell out of the saw, broken in half, I have never found where it came from. We just laugh at it, It is a bad saw. I bought the 12 Rockwell/delta planer the same week, Oh boy did we have fun with that, instantly went through the set of knives on it, maybe 3 passes, I said what the heck. I called delta and told them this is the biggest piece of junk I have ever seen, I said for $1300 it should put a finish on the board when it comes out, and it should have carbide knives, I said, If I had know it was made in Taiwan, i would have bought a grizzly. and saved $500. And gotten a better planer. She said, I'm sorry, I can send you some new knives. I sold it. Still have the saw though. Never had problems with the bearings. Hope this helps.
Feb 21, 2011 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
Reduce bandsaw speed to cut metal
My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Logo
259 people viewed this question
Top Delta Woodworking Saws Experts
Frank Mangiapane
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a Delta Woodworking Saw Expert? Answer questions, earn points and help others
