Question about Acer Aspire 6930-6771 Laptop
Same looked for the switch but i can't find it!!!
Is there a wifi switch off button on my desktop?
Yes it will be in the settings someplace .
Sep 07, 2015 | Computers & Internet
How can I obtain a service manual for KitchenAid microwave KHMS1850S,need wiring diagram to interlock switches.
Pulled up a schematic on this will try and help the first pic looks as though you removed the secondary switch the bottom one if so that is the wrong switch it should be a normally open switch that one is normally closed this switch goes up top on the other side of the primary switch the one with 3 terminals, look at the second pic the switch with 3 terminals that red wire in the wrong spot the skinny orange goes there the switch I just told you to put up top the red goes to one terminal the white and brown middle form the 3 terminal goes to the other terminal, the blue/white and blue go to the bottom switch this is a normally open switch if you don't know how to read a switch look at the switch look at com follow the line to where it stops if it is NO=normally open, NC=normally closed your primary switch is in the right spot you want the switch next to it to be NC and the bottom switch NO it blew the 20 amp fuse once you correct the switches and wiring and put in a new fuse if you have no power then it blew past the fuse and burnt out the filter board happens some times about 60 bucks let me know if this helps
Jan 25, 2015 | KitchenAid Microwave Ovens
I have a 1993 gmc jimmy and I can't find the windshield wipers on and off switch
The wipers are controlled by the multi functions turn signal switch.
A thumbs up would be greatly appreciated if this answer is helpful to you.
Dec 19, 2014 | 1993 GMC Jimmy
Reverse lights stay on in every gear
Well, the only thing left is the switch. It's probably either stuck in, or broken to where it's always showing as on.
Is it Auto or Manual? On some automatic transmissions, the Neutral Safety Switch doubles as the reverse switch, so that's the one you'd want to ask for. Manual trans would have the reverse switch.
Go to your favorite auto parts website and look up your vehicle. Then look up the switch. It'll give you pictures of the part, then that might help you identify the switch, and give you a price. Looks like around $10 or so around here.
There are few switches hooked to that year manual transmissions, possibly only one: the one you're looking for.
How to test:
With the car on jack stands, put key to ON position so the lights come on.
Under vehicle, look on the transmission for components with an electrical connector attached.
Disconnect the electrical connector and see if the lights go out. If there's more than one, try only one at a time. The one that turns out the lights is the one you want.
Hope that helps.
Good luck! :)
Apr 19, 2013 | 1982 Chevrolet El Camino
I'm looking for a pressure switch for a sanborn silver bullet #034-0091 any ideas
I am not sure what type of pressure switch you are looking for but if it is a low or high pressure switch for the air conditioning, then you can purchase that through a parts store.
Dec 21, 2012 | Cars & Trucks
My 95 toyota camry brake light stays on
Ive got a 92 Tercel. Had this same problem. Look around on the floorboard of your car. Look for a small rubber disc, or broken up pieces of the rubber disc.
If you see the pieces or whole hard rubber thing on the floor, then the rubber disc that goes at the point where the brakelight switch touches the back of the brake pedal has fallen off.
When that disc falls off the brakelight switch touches bare metal, and the switch is grounded which makes it stay on all the time.
Climb under the dash with a flashlight and look at the back of the brake pedal. Find the brakelight switch, look at the point where the switch contacts the pedal. See if the rubber disc is missing. If it
is missing find a small piece of rubber to superglue on the spot where the switch makes contact.
If the disc is there the brakelight switch is probably stuck. If its stuck you will see a gap between
the switch contact and the brake pedal. If its stuck get a replacement brakelight switch from an
auto parts store.
Aug 06, 2011 | Toyota Camry Cars & Trucks
I am looking for the reverse light switch on my 2002 TDI with an automatic transmission. I have looked at several posting, but they all seem to be standard transmissions. Any idea when it is located on...
Hi, I think the reverse switch is integral to the park/neutral switch. I'm looking at that switch, and it has too many pins for a plain park/neutral switch. See below.
Jan 25, 2011 | 2002 Volkswagen Jetta TDI
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
Where is the fuel tank switch for the 1986 F 250 pickup ? I just bought the truck used & can't seem to find the selector switch.
it depends on what part of the switch your looking for. in the cab its on the right side of your heater control unit. but the actual switch is under the drivers side in front of the first fuel tank inset in the frame rail. it will have fuel lines going in and out and an electric connector.
Dec 09, 2009 | 1986 Ford F 250
HONDA power washer ON-OFF switch
more than likely the switch complete the circuit and allows the engine to run you canjumper the switch and see if it runs, if so, you can buy a switch from auto parts store and mount it
Aug 19, 2009 | Honda Pressure Washer PSI 3000
Acer Aspire 6930-6771 Laptop Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
