Can i hook an rgb cable up to this tv? i am trying to connet my toshiba satellite to my plasma tv but cannot seem to get the correct cables. first i bought an s-video cable but my laptop does not have a port for the s-video. then i bought a vga cable but my laptop again does not have a port for this. i have wasted at least $30 on cables that i will never be able to use and i am just trying to use my tv screen as a moniter. i looked in the user manual for my laptop and found out that the sreens can be connected but through an rgb cable. so i am wondering if you know if this tv has an rgb port?
    Problem Solver:
  • 8 Answers
Will it connect by using a standard hd-tv cables, or hi-def cables
Posted on Jul 18, 2009
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Screen shattered I want to hook up my mini Toshiba Laptop model number NB505-N508BL to my Toshiba tv. How do I do it and what do I need to do it? I think you messed up on the tv part i have a Toshiba tv...
1. Get an RGB cable.
2. Plug one end of the cable to the laptop VGA/RGB port.
3. Plug the other end of the cable to the RGB/PC input port of the TV.
4. Select the output of the laptop to the VGA/RGB port.
5. Press the Video button (usually with a sign of an arrow inside a circle) and choose PC.
Jul 02, 2014 | Computers & Internet
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
I have a 50'' Pioneer plasma T.V. and can't seem to find a place to plug in an HDMI cable, can you help. Model no. is: PDP 507CMX. The T.V. has the following plug-ins: one that says RS232C; one that says...
An older television might have DVI instead of HDMI. the difference is that HDMI also carries sound while DVI does only video. You may need a converter box or another converter cable.
Feb 05, 2010 | Televison & Video
How do we make my TV capable of receiving regular local channels without cable or satellite hook-up?
You would have to hook up an external TV antenna on the UHF/VHF band and run a coaxial cable from the antenna to the TV and plug in the "Belling-Lee" connector into the "Antenna" socket at rear of unit.. This should enable reception via "Normal TV"
Jan 24, 2010 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Pc to tv
hook up an RGB cable & under display settings on your laptop,
change from one display( there should be 2 ) to the other, by clicking on it
Feb 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Breakout cable usage
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Oct 15, 2007 | Panasonic TH-42PWD5UY 42 in. Television
Televison & Video Logo
286 people viewed this question
Top Televison & Video Experts
