Question about Car Audio & Video
Fitted towbar to mondeo TDCI 2004 could you tell me corresponding colours for indicators, stop and tail lights to be joined too from plugs on towbar. please.
  • 3,230 Answers
Can you please explain your problem in details... so i can help you with regarding information.....
Thanks
Posted on Jul 18, 2009
I need the wiring colour coding for the rear lights of a 2000 v40d as im fitting towbar electrics
Your post:
Hi There.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.
Good Luck
Apr 07, 2011 | 2000 Volvo V40
Were can i get a free diagram of the wirering for the lights for a ford focus h/b 2003 so i can fit my towbar.. just the wirering in the boot
Go into the boot and access the tail light clusters under their covers in the boot rear corners. Take a lead (you can buy double adapter spade connectors) from (1) a tail light, (2) a brake light, (3) the right indicator, (4) the left indicator. (5) a solid earth wire. Try using different colour wires, making a note of each source and each corresponding colour. Tape them together and lead them to the trailer plug. There is a set international configuration for the trailer plug connections which is shown below.
Apr 06, 2011 | 2003 Ford Focus
Have plug in towbar electrics for 52plate passet saloon need diagram to wire plug at towball
Hi There.
Good Luck
Jun 02, 2010 | 2002 Volkswagen Passat
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
2001 vw golf 1.4 wiring details for towbar plug/socket.(colour coding)?
Left indicator - Yellow to Black/White
Right Indicator - Green to Black/Green
Left Tail - Black to Grey/Black
Right Tail - Brown to Grey/Red
Fog - Blue to Grey/White
Brake - Red to Black/Red
Earth - White to Brown or Body earth above/behind Left hand Light
Oct 02, 2009 | 2001 Volkswagen Golf
Ford focus c max towbar electrics
ARE YOU READY
L.H. STOP AND TURN ( YELLOW )
R.H. STOP AND TURN ( GREEN )
TAIL, LICENSE, SIDE MARKERS ( BROWN )
GROUND ( WHITE )
NOW THE COLORS ON THE VEHICAL ARE GOING TO BE DIFFERENT AND YOU WILL NEED A 12 VOLT TEST LIGHT FOR MAKEING SURE YOU HAVE THE WRITE WIRES FROM THE CAR TO THE TOE BAR, DON'T NEED BACK UP TIGHTS FOR THIS
Aug 25, 2009 | 2004 Ford Focus
I've bought a second hand towbar for my golf Mk3 1.4 - i just need to know what wire feeds what so i can connect it up. Neal.
the best way to wire it is to get a tail gate board off a trailer and plug it in to the towbar then wire red to stop n tail lights green or yellow to the earth what other orange or brown to indicator sum wires may differ in colur wat colour wires do u have on the towbar
Aug 24, 2009 | 1995 Volkswagen Golf
Fitting instructions for the towbar electics on a Renault Trafic 2006
Behind the left reversing light is a grommet that you can put the towbar wire through, and just behind this is a large black connector, this has all the wires for the towbar, unfortunately there are several wires of the same colour that do different things, best use a test lamp on each one as you connect them. The indicators are "self monitoring" so you do not need a buzzer or light on the dash to tell you that the trailer is working, when you indicate with the trailer connected the ticking sound of the indicators changes to a pinging sound.
Aug 02, 2009 | 2006 Renault 18I
I need to find out what colours the wires are inside the car rear lights for fitting a towbar to a ford mondeo 1996-2000 2.0l hatchback.
Blue - L/H Indicator, Blue/Red - R/H Indicator, Purple/Yellow - Fog, Orange - R/H Side Light, Orange/White - L/H Side Light, Purple - Brake
Jun 11, 2009 | 2000 Ford Focus
Will a 2003 mondeo tdci engine fit into a 2002 mondeo tdci
They should be. The SVT Models stay Very Consistent on the Motors.
Jan 21, 2009 | 2002 Ford SVT Focus
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
