Question about Epson Stylus CX4800 All-In-One InkJet Printer
Cx4800 red not printing
My printer said i was getting low on ink. i had the cartridges refilled and the red ink is not working. i tried to do the deep cleaning etc... and it still doesn't work. i replaced it with a compatible "mipo" ink cartridge and it still doesn't work. any idea why? just the red is not working - the others are working fine.
  • Anonymous Dec 11, 2007
    No matter how many times I clean the heads or replace the cartridge, whenever I run a print nozzle check I only get about half the amount of red printing I should. Cyan, yellow, and black print fine, but only the bottom half of the red image shows.
Deleted painter by mistake how do i reinstall it?
Posted on Apr 28, 2008
I had the cartridges refilled the yellow and red ink. After I renew two T0604 and T0603 ink. It doesn't work. any idea why? Please tell me why and show me how to do it. Thanks
Posted on Mar 23, 2008
My TX 100 will not print. I have replaced black cartridge thinking it would change things but no. The green button shows and the red one shows (the red one shouldn't) and when I press 'print' it...
Epson ink cartridges have memory chips. If you refill a cartridge it will still show as empty until the memory chip has been reset. The printer will not normally print if it thinks the ink is empty. This is to protect the printer as the ink is energized as it is used.
Refill ink sellers on line usually have the Chip Reset tool available to buy (SK168-II).
Apr 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Canon MF960 will not print yellow
The yellow may be clogged. Try cleaning the printhead by removing it from the printer and soaking the bottom (half inch deep) of printhead in warm window cleaining solution for a few hours.
303Electronics eBay Stores
Jun 05, 2017 | Canon PIXMA MP960 Printer
Restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
Aug 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Replaced cartridge, unrecognized
Try removing the cartridges and unplug the printer.
Plug it back in and try to install the cartriges.
Dec 31, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus cx4800 won't print
Hi, reason we sell epson printers are they are the cheapest to run, but they do get alot of problems with the print heads, if you change from using refill ink kits to compatible ink cartridges you would not have to reset the chip each time, otherwise you will have to change to a more expensive to run printer like the HP, or Lexmark, lexmark is the most expensive for cartridges but it has the print heads built into the cartridge and not the printer itsself, epson only have the chip on the cartridge.
You can use the refill kits on most HP & Lexmark without having to reset the cartridge all you need to do is refill it.
but for every 3 for example you may have to buy a new cartridge which will be more expensive, ie if you get lines through your print, as the print head will probably get blocked on cartrdige.
Happy New Year
Dec 10, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Printer cx4800
Inks aint Inks, buy epson cartridges and hope that the print head has survived the invasion, will probally need a few more cleans but with good ink. No Promise on survival.
Nov 09, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
135 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
