Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Seems there is no gas getting through the carb.......i cleaned it and blew it out, also it i feed a bit of gas in it revs rite up....
  • 154 Answers
Unplug fuel line repl fuel stone on the end
Posted on Aug 01, 2009
I have a echo 330 evl it ran good till i left it set 3 years it started easy wont rev got a rebuild kit soaked in carb cleaner all nite blew it out assembled it put gas in started still wont rev
air cleaner is clean? was rebuilt ? good spark plug? is there a air / fuel adjustment screw or a high / low idle screw on the side of carb. that may be out of adjustment? fuel lines are in good shape? (not cracked or broken sucking air in)?
Jan 11, 2016 | Echo Garden
Cant get the carb to take gas
if you are knowing anything about carbs, then before do anything else first get something a bit heavy and gently tap on the feeding part of the carb so to shake the needle to move or if there is any dirt to move and fuel gets in the carb. if not manage then the carb has to get stripped and clean the needle and make clean carb in order to work.
Sep 27, 2012 | Isuzu Pickup Cars & Trucks
Been stood for about 10 years high revs all for carbs work low revs only 2 works and it's over fueling
take it to a shop and have the carbs sinked and add a bit of seafoam to gas to clean out everything as this helps alot
Jul 12, 2011 | 1994 Honda CBR 900 RR Fireblade
Hi, victa 550 powercut, 10 yrs plus old, problem apart from old and used is it starts runs and dies then just when you think its gonna stop it revs up again and dies and revs and dies and revs and...
Take apart the carb and give it good cleaning maybe even but a rebuild kit if available. also disconnect tank hose from carb and empty tank into clear glass jar. Sounds like there might be some water in your gas. In the glass jar you will see a clear line of liquid at the bottom that would be water, even just a little will give these similar symptoms. Good Luck....
Mar 09, 2011 | Garden
I own the 10685, mowed 6 times this year and on the 7th out of nowhere it developed a problem. Primed as usual, starts, runs about 30 seconds, quits. If I catch it in time I can hit the primer again and it...
Just a suggestion O.K?
Carefully check the small fuel lines. To and from the bulb. Make sure the bulb fills with gas.( at least two thirds full. ) There is a small fuel filter on the end of a small fuel line in the tank. A small hook of stiff wire will dig that out. Good luck !!!!
May 14, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Jonsered 2171 no gas going to carb. Put gas in carb run for few sec's. Blew out fuel filter seems to be fine. Not much use on saw.
the reason is you need to clean out the carb,if they dont get used much the oil/gas mixture turns to a varnish in the small carb ports and fuel can no longer get thru the carb
Mar 28, 2010 | Garden
My 96 magna starts, but wont rev up. I installed new plugs, drained the carbs, blew the fuel lines,changed the gas,checked all vacume lines,removed the air cleaner,& blew air through the top bowl...
put air cleaner back in the airbox as it is needed to create proper vacuum.blowing pressurized air into the openings on the carb could cause the float needle valve to stick to the seat.make sure your control cables are not in a bind, make sure fuel flows to the carb with pressure from pump (not just gravity feed)
Mar 18, 2010 | 1996 Honda VF 750 C Magna
2002 jr 80 will idle but will not rev up
carbs really need to be inspected-a manual is a must-or a similar *** make-if oil n gas mix is rite ratio then ur ok-look at the electrical for any cuts,corrosion or looseness-no wheelies
Sep 09, 2009 | 1978 Suzuki GT 380
Lawn trimmer runs but won't rev
You need to clean the carburetor. Remove & disassemble. Use a Den Tek Brush,
(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean small portals in carb. Spray carb. with carb. cleaner. make sure the small screen in carb. is free of debris. Reassemble and start. If this doesn't work, buy a carb.kit and replace the needle valve, gasket(s), small screen, & diaphragm.
Jim
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Mower won't run
check the fuel needle valve adjustment it should be turned all the way in to the right & back out 1-1/2 turns that should help get it started
Jun 04, 2009 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
85 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
