Kenmore 300 won't start spinning after water fills
Kenmore 300 - after the water fills up, the machine just hums and the washing cycle does not begin
  • kamala_dg Jul 23, 2009
    Thank you for the response to the Kenmore 300 issue with the humming after the water fills. We thought it was the switch, however, the water does drain. To give more detail, once the water fills and the humming starts, if we rock the machine, the cycle will begin. Do you still think this is the motor coupling? or could it be something else? I thought possible a balance issue since the machine starts the normal cycle if we rock the machine? Does this still sound like the motor coupling?
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this helps you.
Posted on Jul 18, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 23, 2009
    Check your lid switch to make sure it is not loose, first. The rocking may actually be causing a loose switch to make contact, then start working.
    I would also still take a look at the motor coupling to make sure it isn't bound up with anything. It is common for the rubber bushing to start to come apart when they go bad. Part of the bushing could be jamming against something, causing the coupling to stick.
    Last of all, you may have a drive motor that is beginning to fail. The motors are generally not serviceable (other than a start capacitor that you can replace). The motors can wear with age and bind up. The instructions I gave you for the motor coupling include how to remove the motor.
    Let me know if this helps you.
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore washing machine fills with water then stops
    turn the motor to see if it moves it sound like the motor
    May 02, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Washer will fill fill with water but doesn't start wash cycle
    it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
    Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
    Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
    Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
    May 23, 2008 | Kenmore Washing Machines
    Rinse cycle doesnt work
    the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
    May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    1,056 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
