Question about Sony Playstation 3 (PS3) Console
Cannot start coannot find correct hard disc - Sony Playstation 3 (PS3) Console
  • 21 Answers
Hello-
This is a very straight forward solution.
Your internal Hard Drive has failed, and needs to be replaced.
YouCAN send it to SONY to "repair" for $170 (and you have to wait 5WEEKS!!), BUT they will only send you someone else's refurbished unit.
With that said, we are able torepair any issues with the PS3 console (and any other console for thatmatter), in a quick and affordable manner. Currently our turn aroundtime is 2 days or less.
Please feel free to call us with any questions you may have.
the GEEKsters
818.306.3012
info@theGEEKsters.com
Posted on Jul 19, 2009
Playstation 3 screen says " cannot start, the correct hard disk was not found." after turned on. will do nothing else. any ideas?
A long shot but it sounds like your hard drive has basically "switched off". If you have a USB sata hard drive dock I can help but its a bit of a complicated process. You need to remove the hard drive from the PS3 and plug it into the USB sata dock then connect it to your computer. Goto Control Panel -> Administrative Tools -> Computer Management -> Disk Managment. Look in the lower area of the screen that appears for your PS3 drive, probably E:, and look if it says "Not initialized". If it does, right click where it says that then click Initialize Disk. Put it back in your PS3 when it is done and hopefully it will turn back on. You will lose all saved data though as the hard drive will need to be formatted.
Hope this helps
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Cannot start. The correct hard disk was not found.
As with many of us current and former PS3 owners you need to have your HDD (hard disc drive) replaces. sorry
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
Software disc
You need your original installation disc(s), or start up the machine and hold down the f8 key and then, 1st boot on the last known good.
2nd, reboot holding down the f8 key and then try the restore method. Most machines have a 4 to 10 gig partitioned on the C drive which holds your restore partition. Else, if you have the orginal OS disc, put it in your cd reader, it will come up with the start up screen for installation. when you get to the install window say OK, then when the window comes up you should have a choice of intalling new or repairing the hard drive ... repair the hard is the correct choice. This should work if there isn't a hard drive problem, or your hit with a virus, or that the hard drive has a bad boot mbr.
Jun 17, 2009 | Computers & Internet
Cannot detect external drive
Try the device on a different computer. or plug the device to the computer. Right click my computer/ manager/ disk management (left panel) & see if the device is there. If not you have may be a driver issue or the device itself is not working. ( you can rectify if the unit is having a issue when you plug it on to another computer)
May 15, 2009 | Western Digital WD Passport 250GB Portable...
Ps3 says cannot find correct hard disc
The ps3 finds hard drives in a specific way. what you have to do is format the hard drive using the ps3 and then you should be fine
Feb 12, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
