Question about Refrigerators
Freezer stopped freezing/nextday refrigerator did the same. Did the diagnostics with the key pads but I'm lost.
  • MasterG65 Jul 18, 2009
    It is an Amana, freezer drawer on bottom, model# ZDBDB6D9, purchased 4 years ago from Circuit City. The freezer thawed out completely/ next day refrigerator did the same. Have power, lights work, diagnostic panels works, fan works.
    Found a burnt overload start/relay.
    Ordered the part as well as a new capacitor.
    Thanks Great Job
    MasterG
  • 10,515 Answers
Sir,
You should have been should the thread by Selecting the ' Solution '. You always need to Rate the solution if an expert have solved that problem!!
Thanks for using ' Fixya ' and Have a nice day!!
Posted on Jul 19, 2009
  • 3,230 Answers
Please give details about the make and model number...
How old is your Refrigerator?
Freezer stopped freezing, means completely stop or cools bad?
explain your problem in details....
Thanks
Posted on Jul 18, 2009
  • Mukesh Kumar Jul 18, 2009
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    Most probably problem is in the relay or capacitor, it's on the back side of your refrigerator near compressor.
    If the relay and capacitor are fine than there is a problem in the defrost timer.
Will compressor have anything to do with freezer stop freezing
Yes, if the compressor stops running, refrigerant cannot circulate so heat inside the freezer cannot be carried to the outside. If the compressor is running and the freezer is still not freezing, the likely reason is that the refrigerant is lost due to leakage.
Jun 20, 2014 | Refrigerators
Where is the reset button on a french door lg refrigerator
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigeratoricon1.png will enter Test Mode 1. Test Mode 1 allows diagnostic operation of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heatericon1.png off.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 2 and hold for 3 seconds. The refrigerator will enter Test Mode 3. Test Mode 3 allows diagnostic operation of the compressor and freezer fan off, stepping damper close and defrosting heater on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and hold for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
Unplug the refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
There is no reset button.
Nov 01, 2012 | LG LFX25978ST 33 " Wide Ultra Capacity...
No display
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the blog798088-troubleshooting-lg-refrigerator-defrost-cycles.htm&opts=1,3,5Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
Oct 19, 2012 | LG LFX25961SB (247 cu ft) Side by Side...
I have a kenmore freezer model# 253 9185211. I had it in storage and brought it home ,connected it.Red light on top is on. I set the dial on 4. I can hear something turn on,but freezer wont freeze. Lost...
the lock is only to prevent the door from opening, it does not cause the unit not to cool properly. If this is a chest freezer, a not uncommon occurrence can happen in similar situations, used for a while, then not plugged in for a period of time, and when its used again stops cooling. The lack of usage causes the refrigerant lines in the cabinet walls to rust, and therefore the refrigerant leaks.
You might consider a service call just to make sure.
Oct 03, 2010 | Kenmore Freezers
The top will not stay cold everything else is working fine.Freezer freezes but the top wont stay cold.
To get £ press down and release the Num Lock key located in the upper left part (To make num lock key on) of the number pad on the right side of your keyboard so that the LED above is lit and release that key. Then hold down the Alt key and type 156 using that number pad.
Let me know if this helped
Nov 26, 2009 | Refrigerators
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Fridge freezer not working but lights on
Our new 10 day old top frig/bottom freezer stopped freezing, then the top refrigerator stopped cooling, but the light was working and you could hear some motor running and an occasional "clicking" sound. One internet blogger adsvised unpluging the appliance for 1/2 hour. Another advised 2 hours. Then plug in the appliance and see if it started cooling/freezing again. Our experience = nothing. We called the repair folk and the new frig/freezer had a failed compressor and a broken timer!! We were not thrilled. Suprisingly the store we bought the ap[pliance from gave us a $50 gift card to compensate for the lost food. They didn't have to do that - so ask for it; can't hurt.
Aug 03, 2008 | Refrigerators
GE refrigerator Model no TFG27PFX
I have no manual either and i would also like to know what the diagnostic panel letters mean too?? Mind is flashing CI.
kim
Oct 16, 2007 | Refrigerators
Kenmore Side-by-side refrigerator
try unplugging it for 5 min and plug back in?
Jun 29, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
