Question about Sony Playstation 3 (PS3) Console
When i turn my playstation on a yellow light comes on and my ps3 immediantly shuts down what is the problem?
    President:
  • 1,139 Answers
Hi, what you are referring to is called the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. As it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 12, 2010
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
PS3 console shuts off with a yellow light and then immediately goes to a red blinking light and then does not start again.
1. Allow your PS3 to cool down. Overheating is known to cause the red blinking lights and the yellow light of death. Turn off your console for at least 20 minutes before turning it back on.
2. Check for a connection problem (loose cable) with your hard drive. If not, restart your PS3. You can also unplug all cables except the power cord and re-plug them back.
3. Lastly, reset the hard drive by taking it out and putting it back in.
( I would power off the console and use a keyboard duster to spray in one of the vent holes, this overheating issue could be caused by excess dust. Is it in an open area with good air flow?
Rylan
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 won't turn on just beeps then switches off
Please check if you get a yellow or red light flash and how many times does the ps3 beep before it shuts down.
If you get a Yellow Light, reason below:
If the hard-drive fails on the PS3 you may get a solid yellow led, The yellow light will show if the console is overheating as well, but the console shuts down so you don't it for long.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then it is suggested to send your PS3 for repairs to Sony Customer Support
Let me know of this helped and please take time to rate my solution.
Wishing you Happy Holidays and Happy Gaming
Regards
Kreative Geek
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
When i try to turn my playstation on a yellow light comes on then it shuts down
This is called the yellow light of death, warped motherboard. While I would not suggest just anyone to try this. You can repair in home, send in fro repair or buy a new one. here is the link for the DIY repair.
Dec 07, 2009 | Sony Playstation 3 (PS3) Console
YLOD
you mite have to reinstaill the firmware for the ps3
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 it turns yellow then immediately shuts down
Its the yellow light of death, its an over heated ps3. Theres not much you can do about it, take it to sony or a computer fixing shop and get the console fixed. These can be fixed at a price of around £35. If you cant get that, get a new ps3, its what i had to do.
Aug 08, 2009 | Sony PlayStation® 3 (60 GB) Console
I just tried to turn my PS3 on it turned on but shut off about 5 seconds after booting up
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/help-support/PS3
or
http://www.us.playstation.com/support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Be sure to rate if it helped or not.
Jun 26, 2009 | Sony Playstation 3 (PS3) Console
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
