SOURCE: Scanning problem
i HAD THE SAME PROBLEM AND HAD TO GO TO ONE CHANNEL AT ATIME IN MANUAL AND HIT THE PROGRAM BUTTON TO RESET IT TO MEMEORY. YOU CAN TELL IF IT IS THE PROBLEM IF YOUR SCREEN READS "ALL CHANNELS LOCKED-OUT"
SOURCE: I have a radio shack
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Testimonial: "Perfect solution for what I want to do. Thank You"
