Question about Bosch Freezers
Set temperature to -18 in freezer bosch gsu2320gb,when we put in meat etc straight from supermarket temp has gone down to -16 is this ok? or can I adjust it
icansurf
  • 72 Answers
SOURCE: Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Posted on Jul 11, 2007
dididsaythat
  • 291 Answers
SOURCE: freezer problems
you could try a 3 in one hard start kit... comes with a copacitor to help start compressors with age and having trouble starting
Posted on Sep 11, 2007
  • 1314 Answers
SOURCE: Set freezer temp
confirm your model number by getting it off the serial plate then go here http://www.boschappliances.com/site_tools/DocumentDisplay.aspx?menu_id=27&menulevel=0302&keyword=KGN33V00GB
Posted on Dec 31, 2007
SOURCE: temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Posted on Feb 25, 2010
  • 389 Answers
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Some products in certain areas of the freezer are defrosting.
any I have seen have a temp dial in them , put a thermometer in it and check the temp often . depending on age it could be needing recharged with freon . but also if it is terribly full that will effect the efficiency of the unit .
Oct 15, 2015 | Freezers
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Temp not going below zero
If that is 0 F it is probably the default temperture and is ok. Above 0 food detoriates quicker and below you get freezer burn faster.
If the controls are locked to that temperature it usually involves holding the button for 3 to 5 seconds to unlock and then adjust. (That is on modern frost free freezers in general)
May 04, 2009 | Bosch Freezers
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Have an RZA30 freezer thats not freezing
was the compressor running? if the unit fails to make temp at a given setting and the compressor is running then turning down the cold control will not make it colder. the thermostat is a switch that turns the compressor and fans (if you have fans) on and off. the different settings only change at what temp the compressor etc. turns off. make sense? so listen for that compressor if it is running and the unit is war you have refrigeration system trouble: restriction, low charge, leak, etc...
cant tell you which without more info.
Apr 23, 2008 | Hotpoint 3.5 cu. ft. / 99 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
49 people viewed this question
Top Bosch Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
ray gallant
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
