I have a Lexmark Z22 printer I have had for about 9 years. I just installed 2 new cartridges and I can't get it to print. I just keep getting error messages. I've tried installing the driver again with the CD, but it often tells me that the cartridges are not installed. Still can't get it to print. Any suggestions? Marjorie Hill mhill41@comcast.net 734 994-9006
  • mhill41 Jul 18, 2009
    Where do I find the waste ink tank to empty it?
    It say s error communicating with the printer and that both cartridges are missing.
  • 13,433 Answers
Hi
could you post the exact error messages?
9 years old, its very likely that the waste ink tank would be full - it would need to be cleaned / replaced to avoid it overflowing, after that it will need to be reset.
Depends completely on what kind of errors your getting.
Let me know.
Thanks,
Ekse
Posted on Jul 18, 2009
  • Ekse Jul 18, 2009
    Its inside the printer, generally under the print cartridges, its not a simple job. What errors are you getting on the printer?
  • Ekse Jul 18, 2009
    No its not the waste ink tank in that case. I think you would be better off buying a new printer at this point.
    Do you still have the old / empty cartridges around that worked? what does the printer / computer say if you place the old cartridges in the machine, does it work normally with the old cartridges I mean does it detect the cartridges and instead of communication error does it complain about low cartridges?
    Do you have another computer in the house that you could try the printer on? Could you test it on a friends computer?
    -- To narrow down if the issue is on your computer or if its on the printer.
My lexmark z22 has never been used, has a new ink cartridge installed, but will only print test pages -- not what i want to save. please help
First you need to connect the printer to your computer with the supplied printer cable including the power cable.
You need to install the printer driver on you computer.
You may need to setup the printer preferences, eg. paper size etc.
You printer is now ready to print your documents. When you have opened an document such as a word document, to print this document click on file - print
Nov 13, 2010 | HP D1560 Deskjet Printer InkJet
Have a Lexmark Z22 printer that skips lines while printing
One of your cartridges is plugged up..take it out and gently remove any excess ink from each cartridge hole with a napkin and try again..
May 28, 2009 | Lexmark JetPrinter Z22 Color InkJet
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
High Voltage Power
I would assume if your printer was hooked up to that high a voltage you would need to buy a replacement part for the power supply. Lexmark website states to replace it with a "Class 2" 20 volt dc at 500ma. Basically you just need to contact Lexmark and get the part and have a printer specialist install the new power supply. You could also try another power cable as well. Sometimes the cable is just fried and nothing is wrong with the printer.
Apr 30, 2008 | Lexmark JetPrinter Z22 Color InkJet
Printer not printing
try a test page, first, please..computer disconnected from printer..
and go get fresh set of printer drivers here
Mar 17, 2008 | Lexmark JetPrinter Z22 Color InkJet
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Lexmark 5150 - Error 0502
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Jan 07, 2008 | Lexmark X5250 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
