Question about Canon PIXMA MX310 All-In-One Printer
Dead Canon Printer MX310
The lcd says "check printer" and shows the number 6000. The power and alarm lights are flashing on and off. The print cartridges are at the far right (replaced a few days ago, and worked fine). I tried unplugging and tried manually moving the cartridges to center. Nothing worked.
Thanks,
Bill Schaefer
  • 2 more comments
  • goerman Jul 18, 2009
    HELP! The expert thinks I have a paper jam. I think I did all he said, but it didn't work. Isn't there a lcd saying "paper jam" when there is a jam?
    I did the paper-jam and cartridge drills, and they did not help.
    Any other ideas beyond a decent burial?
    Bill
    Well, none of the suggestions there worked.
    Bill
  • goerman Jul 25, 2009
    Thanks for your thorough suggestion. I tried it and it doesn't work, so I have decided to get a new printer. This one is way past the warranty period, and I don't want to put any more money (or time) into it.
    Bill
  • Canon Master
  • 13,433 Answers
Reset the printer by turning it off, then turn it back on.
if this doesn't solve the problem theres probably a paper jam, even a very small part of paper can cause the jam or it can be caused by pretty much anything thats not supposed to get inside the printer.
here are my instructions for clearing paper jams:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it byholding it with both hands and pulling firmly. The goal is to keep thepaper from tearing. If several pieces are jammed together, try pullingout the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Dothis step especially if the jam message comes up repeatedly without anyobvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner orink cartridge and paper trays, close any doors you opened and turn theprinter back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Loada piece of thick paper, for example photo paper and press the resumebutton (may be diffrent button on diffrent models) a few times to theprinter picks up the paper and puts it through the machine.
Here is what canon suggest:
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remainsinside the machine, turn the machine off, open the Scanning Unit(Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
Dead Canon Printer MX310 - bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step (1), all print jobs in queue are canceled. Reprint if necessary
Also, have a look at what other people have said/ done with the same problem:
http://www.fixya.com/support/t159885-error_code_6000
Posted on Jul 18, 2009
  • Ekse Jul 18, 2009
    Paper jam / anything else jammed inside that's not supposed to be there.
  • Canon Master
  • 6,487 Answers
That will be a great thing to do and definitely with the new printer everything should be working fine there, feel free to contact us back here for any concern in the future....
Posted on Jul 25, 2009
    President:
  • 1,197 Answers
The error ur experiencing is definitely a paper jam error ... but it neednt be just paper thats causing the jam... it cud be any small dust particle too... if u say u ve already checked the paper tray, nothing that could cause an error, then tryy unplugging it from the USB cable, there is a lock on the backside of ur printer, open it and inspect for possible paper jams...
get ur flashlight and aim it in every little corner.there cud be even a candy wrapper ( yes i ve seen it myself this happening) sticking out from the feed ... if u find it pull it out with a pair of tweezers.
if u still dont find anything... i wud suggest turn it all upside down and give it a gentle shake (try this.... but be careful... if u need a hand take somebody's help if u feel its too heavy.... just shake it gently dont shake it too hard as the sensors cud come out of alignment...)
I suggest a thorough going over with a flashlight into every crevice before calling for repairs. Another suggestion: Keep anything and everthing away from your printer tray and feeder opening
always remember ur not just looking for a paper thats jammed it cud be anything from a small pin to a rubber or a candy wrapper....
if ur still not having ur problem fixed...... then it means there is a either a broken part inside, bits of which cud be blocking the feed...or a sensor problem.....
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.... we ve tried all that we have to save us the time and money for a service call.... beyond this its more than justifiable to call canon..... thats the proper way to go about...
thank you for using Fixya
have a nice day
Good Luck
Posted on Jul 19, 2009
    Genius:
  • 1,689 Answers
Hi bill,
as recommendations from Canon, please try the solutions below. it is a solution for a printwer that is no longer responding.
1. Configure printer driver to correct port 2. Start Windows Print Spooler Service (Windows Vista/XP/2000) 3. Disconnect and reconnect the USB cable to ensure a secure connection 4. Restart the computer 5. Uninstalling / reinstalling the MX300 / MX310 drivers (Windows)
i hope the links work, if not, let me know
Printer error 6000
Hi check paper feed for blockage. & Turn power of at the PowerPoint..& turn back on.good luck..
Aug 22, 2016 | Canon PIXMA MX320 Color USB InkJet Printer
Mx310 makes an alarm sound while the power buton is flashing , any ideas ?
If you use the printer connected to your PC, you should get some error message when you send a print job. If you use the printer as standalone (without PC), count how many times the power LED flashes, then check the Canon website for explanation of the problem. Usually the LED will flash few times than pause before flashing few times...and so on.
good luck with it!
Jun 16, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer screen wont turn on and alarm light on.
Check the print head. Get a cloth and clean out the print head area.
Aug 28, 2014 | Canon PIXMA MX310 All-In-One Printer
Turn on machine & alarm immediately comes on. Flashing check printer 6000.
Are the cartridges in working order. I had similar problem with another make of printer when printer lights kept flashing and one of the cartridges was defective.
Feb 26, 2014 | Canon PIXMA MP170 All-In-One InkJet...
Canon mx310 is reading "check
Error 6000 is a service error, meaning that the printer needs to be taken into a repair shop.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board.
Given the complexity of the error and the cost of a new unit, you may find that it works out much cheaper just to buy a replacement unit.
Hope this helps
Lucas
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Printer alarm goes off with error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 14, 2010 | Canon PIXMA MX310 All-In-One Printer
The lcd says "check printer" and shows the number 6000. The power and alarm lights flash on and off. The print cartridges are in the far right position. I tried unplugging and moving print cartridges. ...
Canon says to reset the printer by shutting it off and waiting 30 seconds before turning it back on. It looks loke you have done that when you unplugged it to try moving your cartridges.
They also say to remove a paper jam if there is one.
If you don't have a paper jam you can follow this link to Canon and try to get some help through email. I don't know if this link is clickable and if not you can copy and paste it in your browser.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jul 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error code 6000
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
May 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Our Canon MX310 printer is flashing Waiting For Report and the In use/memory light is on all the time. There are not reports to print as far as we can see
  1. Remove all print jobs at your computer
  2. Turn off printer
  3. Disconnect printer power supply
  4. Wait 30 seconds
  5. Reconnect printer power supply
  6. Turn on printer
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
Jul 15, 2008 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
614 people viewed this question
old marine
old marine
