Question about Electrolux Washing Machines
How to unclog drain pump on electrolux washing mahine
2 Suggested Answers
SOURCE: Fisher & Paykel GWL15 washer won't drain. A
Hi There,You could bail out as much water as possible,Then If you lean the machine back against the wall,(with machine unplugged) you could remove the bottom plate (if fitted) and you will see the pump with a fan attached,Try turning the fan back & forth it may loosen the obstruction and you could then pump the water out before removing the pump for a service,A the front of the pump you will see a small plastic locking clip that needs to be held out while you turn the pump anti-clockwise for removel.Note treat everthing to be live on this machine if plugged in.(unplug machine before attemting any procedure) Best Regards.
Posted on Aug 21, 2009
Maytag washing mahine makes grinding noise when draining water cycle
pump could have a bad bearing or there could be dirt or sand in the pump itself.
Jul 01, 2017 | Maytag Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
Where is the drain pump on a Electrolux front load washer
Good Morning Friend,
I understand that you want to know where the drain pump is located on your Electrolux washer, model# AWF 1435. In researching the model number you provided, I show that this was manufactured in France. I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you where the drain pump is located in your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux AWF 1435 Front Load Washer
Not draining burning smell electrolux front load
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 25, 2012 | Electrolux EIFLW55H Front-Load Washer with...
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Older model speed queen
check the water pump and the center tub seal to see if it coming from one of the two if the pump is restricted the water can come over the sides of the tub
Apr 25, 2008 | Speed Queen AWS52NW Top Load Washer
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
704 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
