Question about Denon AVR-1707 Receiver
No sound or display but power
K so i was had the system going and then it kicked out which wasnt normal and then i turned everything off let it cool down then to rutn it back i found i had power but no display nor sound plz help
  • Anonymous Dec 25, 2007
    no sound power light flashes
  • Icarus Cheng Mar 22, 2008
    same problem.
You may have toasted the amp. You cab try reseting the microprocessor by using the hard power button and the a b speaker buttons. turn the unit off using the power button. hold the a and b speaker buttons and while holding turn the unit back on. screen should flash a couple times. release a and b buttons. good luck
Posted on Mar 30, 2008
  • jstorz Mar 14, 2011
    Or, pure direct mode is on(which shuts down the diplay) and H/P Only is engaged (erroneously) which shuts off the speakers (H/P being headphones), blow the dust out of the H/P socket, press the Pure Direct button-Hope it helps
  • patgolfs1 May 24, 2011
    On 5/24/2011, I read this individual's suggestion and figured I'd give it a try on my AVR-1707 as I couldn't get any sound out of it although the tuner appeared to be operating fine along with various modes, etc. I did exactly as instructed and when I powered the unit back on, the sound rang out true and clear. Thank you so much, Guest...I deeply appreciate your expertise!!! I'm so happy!!! Pat
COMPRESSER KICKS ON (blows cold)only ON LOW IF YOU TURN BLOWER ON ANTHING BUT 1 the ac light goes out and compressor kicks off, changed the climate control thing and that didn't fix it!!
that sounds like normal operation to me. might be low on charge therefore won't kick in on high speed due to not damaging the system and running the ac compressor to cause damage. have the system checked at a local shop. if ok, then recheck that everything is plugged in. all sensor on the ac lines. sounds like it might even be the low side cut off switch or plugged orfice tube or something along those lines...best left to a professional with a machine where they can monitor pressures, and proper operation and see what's going on.
Apr 15, 2017 | AC Cars & Trucks
Hanns g hg191a
right click your mouse when no programs are running..
the menu should give you a screen resolution option, start there
if that doesn't work, find your control panel, click in this order
Control Panel
Appearance and Personalization
Display
Screen Resolution
Oct 18, 2013 | Computers & Internet
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
Hello, I have a prob with my Sony HCD-RV999D I just bought it from a friend, I plug the outlet everything is normal, I press the power button, the system turns on normally, but after 3 second it turns...
The reason this happens is because it takes about 3 to 5 sec. for the output circuit relay to kick in after power up, im sure at this point is when your receiver shuts off and flashes red. You have a bad output Transister its shorted to ground and the sony's protection circuit kicks in and shuts it down. Unless you are a electronic Tech. you will have to take it in to be repaired its going to be about 120 dollars to repair. Now im assuming your speakers are ok, if you have them hooked up when you do this try disconnecting them and try to power up if it does you have a shorted speaker, but normally Sony just displays overload protection on the display. Im sure you have a shorted Trans. sorry for the bad news good luck.
May 18, 2010 | Sony Audio Players & Recorders
IBM X60 laptop won't start
It really does sound like a hardware problem, perhaps a motherboard/processor/memory issue. If there is no beeping but just humming that is just the fan and drives kicking up.
I would recommend you take it into a repair shop and have them diagnose the issue.
Mar 20, 2010 | IBM ThinkPad X60 Tablet PC
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
It's 945GCR Motherboard. When the jumper is kept in clear mode it is going on. when it is in normal there is no display. I've checked RAM and Power Supply. Everything is fine. Can anyone assist me!
Please check the capacitor near processor, 1000uf or 2200uf. do you see the the top of it is change shape i mean convex. if yes, just replace it. If not, turn on the pc without RAM, do u hear beep sound? if beeping its normal but the controller or chip set is not work good
May 04, 2009 | Intel D945GCL Motherboard
Motherboard
go to www.biostar.com.tw, you will find everything you want..
Jul 26, 2008 | Computers & Internet
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Denon AVR-1707 Receiver Logo
222 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
