Samsung Sme-2220, Sde-3000 Logo
Johnny Jefferson Posted on Aug 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to find the manuafacturer of the sde brand television
I need the tv codes for the sde to program a xr2 xfinity remote control
richie46
Level 3:
Top Expert:
  • Samsung Master 12,962 Answers
  • Posted on Aug 30, 2016
richie46
Samsung Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945430
Points
58151
You get remote codes , if any, from the provider of your cable services.
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
1helpful
I need Mitsubishi electric tv codes I am using a XR2 xfinity remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.....
http://electro-medical.blogspot.com/
What code will work on an Xfinity XR2 remote to pair to a 39" Emerson TV model # LF391EM4F?
Sam, Emerson universal remote codes, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://customer.xfinity.com/help-and-support/xfinityremotecontrols
Comcast Remote Codes Program Your Remote Control
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
2answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Xfinity xr2 remote button and guide button does not bring up the main menu or guide
Try by set it with an other code said to your TV brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Program my Comcast Xfinity remote control for Olevia
(Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Im zoomed in on the xfinity guide! i have the xr2 remote and the x1 cablebox
XR2 doesn't have the ability to zoom in / check your TELEVISION remote. ( one that came orig with tv ) and see if it can be adjusted there. if that fails physically unplug your television to see if the setting will reset to default. if that fails try a different hdmi input. GOOD LUCK!
Top Samsung Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
