Cars & Trucks Logo
David Plaice Posted on Aug 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anyone know how to fit a set of knight rider led lights to a mini Cooper. Need live feed from under the bonnet.. ?? Anyone got any ideas please..??
deton8 von Splosion
Level 3:
  • Mini Master 3,342 Answers
  • Posted on Aug 30, 2016
deton8 von Splosion
Mini Master
Level 3:
Answers
3342
Questions
6
Helped
928752
Points
54123
Hello David Plaice,
If you PLAN on NEVER taking you vehicle off of the movie set...
It is likely
you won't find out how the police, military, fire & para-medics (even we medics) feel about such an
EGREGIOUS, fragrant & flagrant violation of the LAW, NORMS... (ET AL). You'd be committing ...
Putting RED and/or Blue lights on the front of ANY vehicle is likely to be greeted by a whole SQAUD of ANGRY officers all taking turns dancing the fandango on your bonnet/hood.
Don't forget to
Put a lawyer on retainer = bad idea.
(I'm just saying).
And away you go...
Switch, relay fuse holders & solder are noted below... (heat shrink
tubing would make it bullet-proof (nearly)).
The classic place to pull a decent battery feed is from the HOT side of your starter solenoid... FOLLOWED IMMEDIATELY by an appropriately sized (in-line) fuse...
Hope I helped.
Marvin
Level 3:
Top Expert:
  • Mini Master 85,242 Answers
Marvin
Mini Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056827
Points
266281
Us the head light switch.
5 Related Answers
kdm56
  • 48 Answers
  • Posted on Apr 12, 2009
SOURCE: Auto wiring
you should use a relay so that the fridge is only powered when your kia engine is running. reason being to stop the towing vehicle going flat if connected direct onto the other battery when parked for a long time.if this wont be a problem as in you have a hook up when parked and not using the towing vehicle just connect the wire direct onto the battery thru a fuse.hope this helps
Anonymous
  • 4803 Answers
  • Posted on Oct 17, 2009
SOURCE: I want to fit some LED strip 'daylight running lights'
First, I would caution you that 99% of the cars that I have to work on for severe electrical system problems are due to aftermarket accessories that have been improperly installed or have failed for one reason or another and have caused damage to the factory wiring harnesses. Plugging into circuits that you don't know what they are can lead to many driveability problems and computer damage as well.
That being said - all of your IGN+ circuit fuses (Those that are hot only with the ignition on) can be found in the instrument panel fuse block located under the left side of the dash. The fuses in the engine compartment al almost allways hot at all times.
Testimonial: "Thank you very much the information was most helpful"
Anonymous
  • 26 Answers
  • Posted on Apr 14, 2010
SOURCE: replace mini cooper fog lights
Best way is to drop the front bumper.
choprboz5
  • 197 Answers
  • Posted on Jun 01, 2010
SOURCE: lights keep going dim on mini cooper s 2007 dashboard
You don't say if it's "just" the dash lights, or if other lights do it as well. Try turning on a dome light and see if the dome light does it along with the dash lights. Do you notice your headlights doing this as well? These are just troubleshooting steps. If multiple light sources (dome, headlight, etc.) do it, then it's most likely a voltage regulator issue.
Anonymous
  • 15 Answers
  • Posted on Jan 30, 2012
SOURCE: engine jerking
To ansewer the Question on the mine cooper jerking. First if you can"t afford a tune up. Replace distriburor cap & definaley the rotor.The coil will do the same thing
Where would the constant live be under the bonnet of my 2003 mini Cooper.....
The battery positive connection to the fuse box under the hood. It is a red cable.
Bonnet on my 2003 mini copper won't close on passenger side
there is a rubber stopper on each side of the front cross frame , screw te passenger side one down until the bonnet fits flat , may have to screw the other up depending on how far out the adjustment was
How to open the bonnet on a Mini Cooper
The hood release is by the drivers left foot rest. To find the release under the hood look at the front grill where the grill starts to bend down on the drivers side under the hood is the release handle.
Have mini cooper (56) and when start engine a car symbol with line above bonnet comes on....does anyone know what this means?
It means your traction control system is off its nothing to worry about there should be a button in your car that says tcs push it it should go off
1helpful
Automotive Brother in law and I are restoring a
what jam jar are you fixing up ,,well anyway a morris like this with ammeter is no problem ,the feed wire from the battery positive terminal ,the amp meter goes in this cable ,not the big one to the starter motor but the thinner one ,if it doesnt have one then the feed will pick up from the starter solonoid under the bonnet ,right what else do you need to know ,how to build and set up the points ,the carb ,tappet settings ,how to convert to negative earthfor the sound system to work
Need wire colour of live feed to revese light to fit reverse warning unit, thanks
i,m trying to find a live feed in the boot of my bmw mini cooper s, it,s a 04 plate can any one help pls
Replace mini cooper fog lights
6helpful
I want to fit some LED strip 'daylight running lights' to my wife's 2003 T3 VVTi 1ltr Toyota Yaris. I am looking for a 12v feed controlled by the ignition switch that I can use as the live feed. I have...
2helpful
Where does the battery go in a 2005 mini cooper s
In the S model it's in the boot under the floor mat.
In the standard model it's under the bonnet on the left sidr of the car (US Drivers side) You'll see the cables going into the plastic battery box.
Top Mini Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sam Akber
Sam Akber
Are you a Mini Expert? Answer questions, earn points and help others
