Question about Linksys WRT300N Wireless Router
Wireless light does not come on - Does not work
Suggestion of pulling plug for 10 seconds did not work
If you know you dropped the router or somethings similar then, Just disassembly the router and check the wireless card on the routers mainboard so it's not loose. My wireless card was loose so now its work OK ;-)
PS! Basicly do this on all your devices with problems even PCs just rip everything out and back and pray.... for me 90% working through my 15 years of gadgets.
//Odanus
Posted on Jul 23, 2009
  • Linksys Master
  • 4,338 Answers
Do a hard reset:
This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Posted on Jul 19, 2009
Will not stay on....
I dont have an answer or suggestion to this. I am having the same problems aswell with these damn headphones. I dont know what to do with em. The longest theyll stay on is about 10 minutes. Then they cut off. But it charges the headphones fine?
May 26, 2010 | Acoustic Research 900MHz Wireless Stereo...
I unplugged a cable now my likysys wireless isnt working after I replugged the cables into the correct ports
Pull out the power plug and leave it out for 10 seconds, then plug it back in......in less than a minute all will be restored.
Dec 12, 2009 | Linksys Wireless-G WRT54G Router
My wireless controller will work with USB only. Doesnt work and has four flashing lights when unplugged. Anyone help??
Look on the bottom of the wireless controller, while it's NOT connected to the usb wire, there is a small hole for a paper clip. Press the button down softly for 10 seconds release, then another 10 seconds release, then plug it back to the usb wire, press the PS button, give it a few seconds to work, then try it wirelessly. should fix it.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Can't use wireless all of a sudden. Have to plug
You can try first changing the wireless settings of your router like the SSID and channel and check if that will fix the problem, if there's no wireless computer working with this router better reset it by pressing the reset button for 10 seconds while power is ON and after that reconfigure it back..........
Oct 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless stopped working. If correctly plugged
Have you tried a hard reset, then setting up the wireless again?
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 10, 2009 | Computers & Internet
My lpatop 2700 worked fine and one morning it wouldn't boot. The power lights come on, the battery is charged but nothing shows up on the screen
Suggestion: Remove battery, unplug laptop. Hold the power button down for 10 seconds. Replace battery, plug back in. That's step one. Let me know if that makes any difference.
Jul 13, 2009 | HP Computers & Internet
Pc will not power up. Green light on power switch blinking like a slow stobe light. I tried un plugging it, did not work. I tried swicthing it to 240v, then back to 120v did not work. I tried an alternate...
The power supply is shot. Best suggestion is to replace it. You need to make sure it is replaced with the same model power supply. Check online for a replacement unit.
Mar 10, 2009 | HP Compaq Presario SR1110NX PC Desktop
Reset password for linksys wireless-g router
Press and hold the reset button for 60 seconds, after you release the reset button wait until the power light stops blinking. If it does not stop blinking, then unplug it for 30 seconds and plug it back in. After that type in at the address bar, 192.168.1.1
Feb 08, 2009 | Arris SURFboard SB5101 Cable Modem
Linksys Wireless Router Stopped working
Try holding the reset button for 10 seconds, while holding the reset button in, unplug it for 10 seconds, plug it back in, but don't let go of the reset button for another 10 seconds. Respond with any results.
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Wireless router doesn't stay on
check the power source.
if the power source is verified to be working ok, try to press the reset button for 30 seconds to a minute while it's plugged in to the power source then turn it off for another 30 seconds then turn it on.
if the problem still persists, there could be a problem with the device itself and if it's still under warranty, replace it
Oct 02, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Linksys WRT300N Wireless Router Logo
1,090 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
