Question about Maytag MER6772 Gemini Electric Kitchen Range
F1-2 fault code persists after sensor replaced
F1-2 fault code, with both ovens affected. New sensor installed last week by professional but problem recurring. The first time it beeped yesterday it was F3-2, but now it is again F1-2. Technician had stated next step would be to replace control panel. Any suggestions?
    Problem Solver:
  • 6 Answers
Re: F1-2 fault code persists after sensor replaced
Sensor is about 40.00 I would recommend replacing it yourself. Part number is 12001656 google the part number for places to purchase it. If you use maytag you will pay through the nose!! I have payed twice now! Control panel is part number 74006213 that runs about 200.00 to 290.00 that is probably not your problem, you just had another bad sensor installed. Maytag doesnt care, they already got you when you bought it!
Posted on Dec 20, 2007
0 characters
3 Points
F4 fault code
Hi Ric,
Fault codes refer to the "clock" component of your range. The exact name depends on the brand you have. For example:
Electronic Range Control
Electronic Oven Control
control board
all refer to the same part.
Usually the F3 and F4 Fault codes refer to the Oven Temperature Sensor (RTD). Here are the steps to take:
1. Check the Connections.
Make sure the wiring is okay between the oven control, oven sensor and sensor harness.
2. Replace Oven Temperature Sensor (RTD).
If the wiring is ok, the Oven Temperature Sensor (RTD) has shorted and it will need to be replaced.
Here is a fairly simple diagram for you:
And below is a link to a video the shows you how to check the sensor:
Hope that helps!
Checking an Oven Temperature Sensor
Feb 22, 2016 | Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
What does F3 mean when trying to on the oven?
F-3 and F-4 are oven sensor failures. If you check the resistance at the electronic control for the sensor input, it should be 1,050 to 1,100 ohms at room temperature.
Replacing the oven sensor should be accomplished by a professional, as improper installation will lead to a quick failure of the new part.
Replacing the oven sensor is an inexpensive repair.
Aug 11, 2009 | Magic Chef Kitchen Ranges
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Maytag Gemini Range fault code F1-L. What is this and how do I fix it.
relates to faulty oven sensor, repalce oven sensor in affected oven
Mar 04, 2008 | Kitchen Ranges
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
Feb 09, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
F1 fault
Here are the fault code for GE:
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
265 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
